29653 Discussions
ENTRY Statements in Function Subprograms
e745200
The documentation says :
"All entry names within a function subprogram are associated with the name of the function subprogram. Therefore, defining any entry name or the name of the function subprogram defines all the associated names with the same data type. All associated names with different data types become undefined."
Well, in the following code, the function subprogram and the entry have different types, and it compiles and runs smoothly. According to the documentation, I should have some troubles. I did not.
Is anyway advisable avoiding entries of different types ? Is it a violation of the standard ?
Thanks for your attention.
[fxfortran]       PROGRAM TFENTRY
       REAL(8)  :: A,B,C,D,E,F
       EXTERNAL :: MFUN, RFUN
       A=1.D0
       B=2.D0
       C=4.D0
       D=8.D0
       mmfun=mfun(a,b)
       rrfun=rfun(c,d)
       write (*,*) a,b,mmfun
       write (*,*) c,d,rrfun
       STOP
       END
       FUNCTION MFUN(P1,P2)
       REAL(8) :: P1,P2,P3,P4
       REAL(8) :: A,B
       A = P1
       B = P2
       MFUN = A+B
       write (*,*) 'in mfun ',P1,P2,mfun
       GOTO 10
       ENTRY RFUN(P3,P4)
       A = P3
       B = P4
       RFUN = A+B
       write (*,*) 'in rfun ',P3,P4,rfun
  10 CONTINUE
       RETURN
       END
[/fxfortran]
This code is fine. What the standard says is that when you assign to MFUN, then any value previously assigned to RFUN is undefined, and vice-versa. Your example never uses the value of the "other" entry. For example, if you removed the GOTO in MFUN and, in the WRITE at line 33 you wrote out the value of mfun, it would be "wrong".
e745200
Thanks a lot for your really prompt response.
Then, I had misunderstood the meaning of "defines" in the documentation.
I did not get it referred to the behavior at runtime, and not at "declaration" time.
Thanks again.
