ERROR 5082
amir_a_2
Hi
i  was using a simple DO cmd ::
  DO ( i.lt.10 .and. error.lt.(1e-4))
and this happened ::
Error    1     error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: <IDENTIFIER>
VS 2013
so i dont know whats wrong here... need help
Lorri_M_Intel
There is not enough information to do anything more than make a wild guess here.
Can you show more of the program?
             --Lorri
amir_a_2
    program Console8
    implicit none
Real::X1,Xm,F(x),Fd(X),error
integer::i
F(x)=tan(x)-x
Fd(x)=tan(x)**2
error=1.0
i=1.0
1 print*,'please enter a number close to  root'
Read*,Xm
      X1=Xm-(F(Xm)/Fd(Xm))
      X1=Xm
i=i+1
error=abs(X-Xm)
  end do
  print*,'root is',X1 , 'error is' , error
go to 1
pause
    end program Console8
TimP
That one line is not complete Fortran syntax.  Perhaps it was intended to be
do while(...)
and some references have said it would be preferable to use
do
   if(.not.( i.lt.10 .and. error.lt.(1e-4))) exit
end do
The error message seems a little off target, as I don't see how appending an identifier could make it meaningful.
amir_a_2
now i changd code to this
    program Console5
!Amir Abbas Falsafi
    implicit none
    Real,parameter::error=1e-4 , pi=3.141592
    integer::i=1
    Real::Xm,T
    Real::F,FF,X,Xm2
5    Read*,Xm
   Xm2=Xm*180/pi
   Do while(I.lt.10.and.F(X).gt.error)
   X=Xm-((tan(Xm2)-Xm)/(tan(Xm2)**2))
        print*,'Xo is',X ,'times repeated=',i
     Xm=X
        i=i+1
   end do
   go to 5
   end program Console5
and now what i get is more interesting
Error    1     error LNK2019: unresolved external symbol _F referenced in function _MAIN__           Console8.obj
Error    2     fatal error LNK1120: 1 unresolved externals                Debug\Console8.exe
mecej4
The declaration of F as real and the subsequent appearance in an expression of F(X) signify to the compiler that F is an external function of type real with one real argument. You have to supply the source code of that function.
If the code is intended to solve an algebraic equation by regula-falsi or something similar, note that the convergence check that you use may fail to do what was intended.
