29653 Discussions
Eclipse Plugin for Intel Fortran Compiler
akenngu
After installation of Intel C and Fortran 11.1 Compilers there is a Eclipse-Plugin for C, but NO for Fortran. Where can I find the Fortran Plugin for Eclipse ?
akenngu
Quoting - akenngu
Hirchert__Kurt_W
New Contributor II
Quoting - akenngu
As far as I know, Intel doesn't support it, but take a look at http://www.eclipse.org/photran/
[I have no personal experience with Photran, but I've read about here in past threads, and most of the contributors to it are from the University where I worked before retiring. If you are curious about the name, Pho-tran was the name of a Vietnamese restaurant that used to be near the UIUC campus.]
-Kurt
William_H_Intel3
We do not supply a Fortran plugin for Eclipse with the compiler kit. There is an elementary Intel Fortran integration supplied with the Eclipse Photran project. You can try that if you are interested in an Eclipse solution for Fortran.
Hope that helps...Bill Hilliard
