29641 Discussions
Runtime error with polymorphic pointer
MDK
[plain]module ifort_bug_mod
    implicit none
    type :: base_t
        integer :: dummy = 0
    end type
end module
program ifort_bug
    use ifort_bug_mod
    implicit none
    type(base_t), pointer :: p_ok => null()
    class(base_t), pointer :: p_err => null()
    type(base_t), target :: base
    p_ok => base ! ok
    p_err => base  ! runtime error
end program[/plain]
As far as I can tell this is a compiler bug (v11.1.051). As you can see, simply associating a polymorphic pointer with a target causes a runtime error.
thomas_boehme
New Contributor II
Quoting - MDK
    implicit none
    type :: base_t
    end type
end module
program ifort_bug
    use ifort_bug_mod
    implicit none
    p_ok => base ! ok
end program[/plain]
That's a bug introduced in v11.1.051. I already reported in in following thread:
http://software.intel.com/en-us/forums/showthread.php?t=69682
As a workaround, you can disable Diagnostics->Generate Interface Blocks and Diagnostics->Check Routine Interfaces. See the above mentioned thread for details.
regards,
Thomas
MDK
Quoting - thomas_boehme
regards,
Thomas
Thanks!
