Edit a value in the Watch window
NBG6
I'd like to edit a REAL*8 variable in the Watch window. But when I double-click the value column and try toentera value with floating-point(i.e. "4.7") I get the error message:
"The value could not be set. Please check your entry."
An integer-value without floating point can be entered.
What could be the reason?
Tanks!
NBG6
IDZ_A_Intel
Using 11.1.060, I can't see any problem editing real scalars or arrays, single or double precision, in the debugger.
Jeffrey_A_Intel
A few details please, such as the version of Visual Studio and the ifort version. If you're using VS2005 or later, try the latest 11.1 ifort release. A bug was fixed in this area recently (but I don't recall exactly which update it was in).
NBG6
Sorry for the late response.
I have Visual Studio 2008 Version 9.0.21022.8 and the Intel Visual Fortran Compiler 11.1.3462.2008 .
IDZ_A_Intel
That's not the compiler version. What is the string that starts with w_cprof_ ?
abhimodak
Probably the following is not the case but I have seen this message if it is an array and I am trying to set a wrong index (for example, array A has lowe bound of 1 and I try A(m) = somevalue with m = 0). Note that the watch window would still display A(m) something but I believe that is whatever the "memory at that location" is pointing to (I don't know the correct wording).
Abhi
NBG6
Oops!
The compiler version is 11.1.035
NBG6
Abhi, thank you. But I think thats not the case. I have this problem with botharraysand scalar variables.
gorbit
I have got the same Problem also by editing REAL*4 values setting a value with a floating point.
The compiler version is w_fc_p_10.1.030 IA32 with Intel Debugger Version 10.1-35 running on VS 2008 Version 9.021022.8 Professional Edition. If it is a bug, has it already been fixed?
best regards
IDZ_A_Intel
NBG6
My collegue has the same problem in editing real values using the compiler version 11.1.035. Recently he updated to 11.1.060 and now he has no problems any more. So I think the bug has been fixed in the new version.
Thank you very much for this hint!
