29288 Discussions
Efficiency of host association for derived-type variables
FlyingHermes
I often heard that the use of derived-type variables in big computational procedures was less efficient than the use of variable based on intrinsic types.
However, I do not really know where does the difference appears.
Therefore, I do not know to which extent the use of derived-type variable will not affect the program efficiency.
For example, when accessing data through host association, is it slower if the data is stored in a derived type variable than if it was not ?
Is there a efficiency difference between this implementation
[fortran]Module MyModule
  private
  public MyType
  Type :: MyType
    real, dimenstion(1:10) :: Sub1
    real, dimenstion(1:10) :: Sub2
    real, dimenstion(1:10) :: Sub3
  End Type
End Module
Program
  use MyModule ,only: MyType
End Program[/fortran]
and this one:
  private
  public Sub1, Sub2, Sub3
End Module
Program
  use MyModule ,only: Sub1, Sub2, Sub3
Host association is resolved at compile-time, and should not have an effect on performance. I think also that it is an overly broad generalization to say that derived types hurt performance. A lot depends on how you use them, especially if you have arrays of derived type and try to use non-contiguous arrays of components.
