With 11.1.065, when compiled with /check:all /warn:all /stand:f03 I get an error that a scalar valued expression is required in the if statement marked #C. But my understanding is that the expression is scalar, as the compiler should select the pure (not elemental) specific procedure ge_foos, which returns a scalar.
Bizarrely, if I swap the line commenting on the lines marked #B and #C around, this compiles with no error, though, despite going nearly cross-eyed from looking at it, I cannot see a relevant difference between the definitions of the interface blocks and the procedures.
Alternatively, if I comment out the statement that makes the unused > operator visible (the line marked #A), it all compiles too.
Thanks for any advice,
IanH
[fortran]MODULE Foos IMPLICIT NONE PRIVATE PUBLIC :: Construct PUBLIC :: OPERATOR(>) ! #A PUBLIC :: OPERATOR(>=) TYPE, PUBLIC :: Foo PRIVATE INTEGER :: comp END TYPE Foo INTERFACE Construct MODULE PROCEDURE Construct_ END INTERFACE Construct INTERFACE OPERATOR(>) MODULE PROCEDURE gt_foo MODULE PROCEDURE gt_foos END INTERFACE OPERATOR(>) INTERFACE OPERATOR(>=) MODULE PROCEDURE ge_foo MODULE PROCEDURE ge_foos END INTERFACE OPERATOR(>=) CONTAINS FUNCTION Construct_ RESULT(obj) TYPE(Foo) :: obj !**** obj%comp = 0 END FUNCTION Construct_ ELEMENTAL FUNCTION gt_foo(lhs, rhs) RESULT(res) TYPE(Foo), INTENT(IN) :: lhs INTEGER, INTENT(IN) :: rhs LOGICAL :: res !**** res = .TRUE. END FUNCTION gt_foo ELEMENTAL FUNCTION ge_foo(lhs, rhs) RESULT(res) TYPE(Foo), INTENT(IN) :: lhs INTEGER, INTENT(IN) :: rhs LOGICAL :: res !**** res = .TRUE. END FUNCTION ge_foo PURE FUNCTION gt_foos(lhs, rhs) RESULT(res) TYPE(Foo), INTENT(IN) :: lhs(:) INTEGER, INTENT(IN) :: rhs LOGICAL :: res !**** res = .FALSE. END FUNCTION gt_foos PURE FUNCTION ge_foos(lhs, rhs) RESULT(res) TYPE(Foo), INTENT(IN) :: lhs(:) INTEGER, INTENT(IN) :: rhs LOGICAL :: res !**** res = .FALSE. END FUNCTION ge_foos END MODULE Foos PROGRAM ItsSpecificallyNotElemental USE Foos IMPLICIT NONE TYPE(Foo) :: foo_list(2) INTEGER :: i !**** DO i = 1, SIZE(foo_list) foo_list(i) = Construct() END DO ! IF (foo_list > 0) THEN ! #B IF (foo_list >= 0) THEN ! #C WRITE (*, *) 'Boing' END IF END PROGRAM ItsSpecificallyNotElemental [/fortran]As an aside: when are we likely to see in IVF the F2003 ability to "override" structure constructors with a generic?
IanH
連結已複製
5 回應
Ian,
The question relates to what is actually being called by
IF(foo_list>=0)
Is this interpreted as
IF(foo_list> (=0))
What happens with
IF(foo_list>=(0))
Also, as a diagnostic, define an operator ".ge." an then change the errant statement to use .ge. instead of >=, does this too report the same error?
Jim Dempsey
IF(foo_list>=0)
IF(foo_list> (=0))
What happens with
IF(foo_list>=(0))
Jim Dempsey
>>Jim, >= is always parsed as an operator equivalent to .GE..
Unless there is a compiler bug, which Ian seems to have an example thereof.
The substitution of .ge. for >= was explicity designed to expose if ">=" were not treated as a single token.
If .ge. works where >= fails, then this is a strong indicator that the token parser broke the ">=" into two tokens. And in which case, this information (works or fails in same manner) may be helpful to your compiler support staff in locating the errant code.
Jim Dempsey
Jim Dempsey
