29285 Discussions
Elemental user defined operator being naughty and hiding rank-specific procedure
IanH
With 11.1.065, when compiled with /check:all /warn:all /stand:f03 I get an error that a scalar valued expression is required in the if statement marked #C. But my understanding is that the expression is scalar, as the compiler should select the pure (not elemental) specific procedure ge_foos, which returns a scalar.
Bizarrely, if I swap the line commenting on the lines marked #B and #C around, this compiles with no error, though, despite going nearly cross-eyed from looking at it, I cannot see a relevant difference between the definitions of the interface blocks and the procedures.
Alternatively, if I comment out the statement that makes the unused > operator visible (the line marked #A), it all compiles too.
[fortran]MODULE Foos
  IMPLICIT NONE
  PRIVATE
  PUBLIC :: Construct
  PUBLIC :: OPERATOR(>)                 ! #A
  PUBLIC :: OPERATOR(>=)
  TYPE, PUBLIC :: Foo
    PRIVATE
    INTEGER :: comp
  END TYPE Foo
  INTERFACE Construct
    MODULE PROCEDURE Construct_
  END INTERFACE Construct
  INTERFACE OPERATOR(>)
    MODULE PROCEDURE gt_foo
    MODULE PROCEDURE gt_foos
  END INTERFACE OPERATOR(>)
  INTERFACE OPERATOR(>=)
    MODULE PROCEDURE ge_foo
    MODULE PROCEDURE ge_foos
  END INTERFACE OPERATOR(>=)
CONTAINS
  FUNCTION Construct_ RESULT(obj)
    TYPE(Foo) :: obj
    obj%comp = 0
  END FUNCTION Construct_
  ELEMENTAL FUNCTION gt_foo(lhs, rhs) RESULT(res)
    TYPE(Foo), INTENT(IN) :: lhs
    INTEGER, INTENT(IN) :: rhs
    LOGICAL :: res
    res = .TRUE.
  END FUNCTION gt_foo
  ELEMENTAL FUNCTION ge_foo(lhs, rhs) RESULT(res)
    LOGICAL :: res
    res = .TRUE.
  END FUNCTION ge_foo
  PURE FUNCTION gt_foos(lhs, rhs) RESULT(res)
    TYPE(Foo), INTENT(IN) :: lhs(:)
    LOGICAL :: res
    res = .FALSE.
  END FUNCTION gt_foos
  PURE FUNCTION ge_foos(lhs, rhs) RESULT(res)
    LOGICAL :: res
    res = .FALSE.
  END FUNCTION ge_foos
END MODULE Foos
PROGRAM ItsSpecificallyNotElemental
  USE Foos
  IMPLICIT NONE
  TYPE(Foo) :: foo_list(2)
  INTEGER :: i
  DO i = 1, SIZE(foo_list)
    foo_list(i) = Construct()
  END DO
!  IF (foo_list > 0)  THEN        ! #B
  IF (foo_list >= 0)  THEN        ! #C
    WRITE (*, *) 'Boing'
  END IF
END PROGRAM ItsSpecificallyNotElemental
[/fortran]
As an aside: when are we likely to see in IVF the F2003 ability to "override" structure constructors with a generic?
Thanks for any advice,
IanH
jimdempseyatthecove
Ian,
The question relates to what is actually being called by
IF(foo_list>=0)
Is this interpreted as
IF(foo_list> (=0))
What happens with
IF(foo_list>=(0))
Also, as a diagnostic, define an operator ".ge." an then change the errant statement to use .ge. instead of >=, does this too report the same error?
Jim Dempsey
Jim, >= is always parsed as an operator equivalent to .GE..
Ian, I'll take a look at this and see what is going on.
jimdempseyatthecove
Unless there is a compiler bug, which Ian seems to have an example thereof.
The substitution of .ge. for >= was explicity designed to expose if ">=" were not treated as a single token.
If .ge. works where >= fails, then this is a strong indicator that the token parser broke the ">=" into two tokens. And in which case, this information (works or fails in same manner) may be helpful to your compiler support staff in locating the errant code.
Jim Dempsey
The use of > vs. .GE. has no effect on this problem. I can make it fail with either one.
Reported as issue DPD200155690. Thanks for the nice example.
This has been fixed in our sources for the next major release.
