Eratic Debugger behavior
Deleted_U_Intel
When debugging a program, I find upon repeated additions and subtractions of breakpoints, that my breakpoints become disabled. Even when I delete one and then add it back in again, appearing to be an enabled breakpoint at this point, it becomes disabled when I run the debugger.
Hoping that the clear option can help here, I find that after I run the clean option for a solution, I get the following error upon rebuiling the project.
Error9 fatal error LNK2023: bad DLL or entry point 'msobj80.dll'LINK
Please advise.
John
I have seen this before - it apparently happens when the DLL named in the error becomes corrupted. This is part of Visual Studio. I suggest uninstalling the Intel Fortran integration and then doing a "reinstall/repair" of Visual Studio, then reinstalling the integration. If you have not already done so, you can download and install VS2005 SP1 from microsoft.com and then reinstall the integration.
Well, that's not good, as it suggests that you have a problem with the system that is bound to occur again.
