29541 Discussions
idb 10 doesn't display fortran module variables
walter_s_
Hi
The idb debugger in the last release of ifort for linux (l_fc_p_10.0.023) doesn't display the module variables.
module mod1
integer mod1_var1
end module mod1
subroutine sub1
use mod1, var1=>mod1_var
var1=1
end
(idb) print var1
best regards
walter steff
Try:
print mod1::var1
walter_s_
Hi Steve, thanks for your replay.
I have tried it but "print mod1::var1" seems not to be a legal statement for idb.
Instead it accepts the following command:
print mod1%%mod1_var1
! mod1_var1 was the name of variable defined inside of mod1
but the result doesn't change:
I would like to say that the printing of the module variables worked fine with IFORT 9.1 and Suse 10.0.
Now I have upgraded to IFORT 10.0 and Suse 10.2 which has a newer glibc (2.5).
I have tried to solve the problem by going back to ifort 9.1 but, probably due to the not supported glibc 2.5, idb 9.1 doesn't read any more the debug symbols.
To complete the info I would like to say also that my code is a mix of fortran and C++ and that the idb behaviour doesn't change by switching the linker between ICPC and g++.
best regards
Walter Steffe
Please report this problem to Intel Premier Support.
walter_s_
Ok. I will do it
Walter
