29376 Discussions
Erroneous Warning for compiler_options
GaetanNASA
The following program,
program main
use ISO_FORTRAN_ENV
character (len = :), allocatable :: res
res = compiler_options ()
print *, res
deallocate (res)
end program main
when compiled with
gkenway@pfe26:~> ifort -stand=f08 t.F90
gives
t.F90(6): warning #7416: Fortran 2008 does not allow this intrinsic procedure. [COMPILER_OPTIONS]
The ifort version i'm using is.
gkenway@pfe26:~> ifort --version
ifort (IFORT) 19.1.3.304 20200925
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
The older versions didn't do this.
Gaetan
Barbara_P_Intel
You are right. That should not be a warning for F2008.  I filed a bug on your behalf, CMPLRIL0-33502.
Barbara_P_Intel
Barbara_P_Intel
The warning message that you reported has been removed in ifort version 2021.6.0. That was recently released as part of oneAPI HPC Toolkit 2022.2.
Check it out. You can download it here
