29279 ディスカッション
Error 1 error LNK2019: unresolved external symbol
Qing_L_
ビギナー
750件の閲覧回数
I'm new in using Fortran.
I am creating a .dll from the following code:
testa.f
      SUBROUTINE TESTA(ID)
      !DEC$ ATTRIBUTES DLLEXPORT :: TEST
      IMPLICIT NONE
      INCLUDE 'params.f'
      DOUBLE PRECISION SVAL,VAL(2*MAXYBOUN)
      INTEGER ID,N(2),NOD(2*MAXYBOUN)
      CHARACTER*1 TYP(2)
      CALL DIRIC(ID,N,NOD,SVAL,VAL,TYP)
      !--------OTHER CODES-------!
      END
and the called function diric is
      SUBROUTINE DIRIC(ID,N,NOD,SVAL,VAL,TYP)
      IMPLICIT NONE
      INCLUDE 'params.f'
      INTEGER N(2),NOD(2*MAXYBOUN),K,J,NEQ,ID
      CHARACTER*1 TYP(2)
      !     DIRIC code                                                     :
      RETURN
      END   ! DIRIC
I get the LNK2019 error:
error LNK2019: unresolved external symbol _diric@32 referenced in function _testa
The error disappears if I remove the character array TYP in subroutine, i.e.
CALL DIRIC(ID,N,NOD,SVAL,VAL)
SUBROUTINE DIRIC(ID,N,NOD,SVAL,VAL)
but I need the array TYP.
Is there any suggestion how to solve this problem? Thanks!
0 件の賞賛
1 解決策
Steven_L_Intel1
従業員
750件の閲覧回数
You must be compiling this code with some non-default options.Maybe you're using /iface:stdcall? Try /iface:stdref instead since the routine you're calling was apparently built that way.
元の投稿で解決策を見る
2 返答(返信)
Steven_L_Intel1
従業員
751件の閲覧回数
Qing_L_
ビギナー
750件の閲覧回数
Yes it is set to /iface:stdcall. I change to default and it works... Thank you!
返信
