29376 Discussions
Error #5082 in transferring a value represented by a pointer to another variable
pranava_c_
A value stored in a structure pointed by a pointer is unable to be passed on in another variable
temp_crowding_dist = pop%ind(1).crowd_dist
 Following error is showing while building the project
Error    1     error #5082: Syntax error, found '.' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . % (/ + - : ] /) ' ** / // > .LT. ...    D:\Crowding_dist\Fortran_code\F_NSGA_II\Crowding_Distence_ref_2\Crowding_Distence_ref_2\crowddist.f90    177
If I comment this line and check the value of pop%ind(1).crowd_dist  in watch window by running upto that line, it is showing the correct value
PS:
TYPE population
    TYPE (individual), DIMENSION(:) , POINTER :: ind
END TYPE
TYPE individual
    INTEGER, POINTER                        :: rank
    DOUBLE PRECISION, POINTER               :: constr_violation
    DOUBLE PRECISION, POINTER               :: crowd_dist
    DOUBLE PRECISION, DIMENSION(:), POINTER :: obj
    DOUBLE PRECISION, DIMENSION(:), POINTER :: constr
    TYPE (gene_bit), DIMENSION(:), POINTER  :: gene
    DOUBLE PRECISION, DIMENSION(:), POINTER :: xbin
    DOUBLE PRECISION, DIMENSION(:), Pointer :: xreal
END TYPE
mecej4
Replace the non-standard component separator '.' by '%'. It seems that the compiler does not recognize the period as equivalent to the % sign in all contexts.
mecej4
If you start using % you have to keep using %. Mixing them is not nice. But you should use % always and drop the dot.
pranava_c_
Thanx very very much. It worked :)
