29487 Discussions
Error #6401 After Just a Change of Versions
Clay_N_
I am just starting to work with a program, XLTRC2, for my research at Texas A&M. I am using Visual Studio Professional 2013 with the Intel 2013 Fortran compiler including the IMSL package. Upon trying to run the exact same project that works for my co-workers I am getting the error message "error #6401: The attributes of this name conflict with those made accessible by a USE Statement.[Variable ex: LOGFIL] ; File: arnoldi-debug-h.f90" for a group of variables in my code. They are not receiving the same error messages when they run the project on Visual Studio Professional 2012.
If I comment out the USE statement for the IMSL_LIBRARIES the error message changes to "error #6404: This name does not have a type, and must have an explicit type. [N1RTY] ; File: Arnoldi.f90" Which I am guessing is because N1RTY is defined in IMSL_LIBRARIES.
Could something in the new IMSL libraries be interfering with the common variables in the project? Or do I have a setting wrong?
The code outline giving the issue is
----Arnoldi.f90------
USE ...
USE IMSL_LIBRARIES
include 'arnoldi-debug-h.f90'
 ndigit = -3
 logfil = 6
 mnaitr = 0
 mnapps = 0
 mnaupd = 0       ! 1 for output, 0 to suppress output
 mnaup2 = 0
 mneigh = 0
 mneupd = 0
  nwarnings= 0
---------End of Arnoldi.f90-----------------
-------arnoldi-debug-h.f90'-----------
      integer    logfil, ndigit, mgetv0,                                    &
                msaupd, msaup2, msaitr, mseigt, msapps, msgets, mseupd,    &
                mnaupd, mnaup2, mnaitr, mneigh, mnapps, mngets, mneupd,    &
                mcaupd, mcaup2, mcaitr, mceigh, mcapps, mcgets, mceupd
      common /debug/                                                    &
-------end arnoldi-debug-h.f90----------------
Thanks for any information possible!
Clay Norrbin
mecej4
Your co-workers could be using different versions of IMSL and the compiler. Either change the name of your variable LOGFIL, or modify the USE statement to avoid the name clash:
     USE IMSL_LIBRARIES, XCEPT=>LOGFIL
where XCEPT is a name that has not been used in the the subprogram.
Alternatively, you can USE only the symbols needed; for example:
    USE IMSL_LIBRARIES, ONLY : N1RTY
mecej4
Clay_N_
Thanks mecej4,
I changed the code to USE IMSL_LIBRARIES, ONLY : N1RTY which it now compiles without any errors. It still is having some problems with running though. At this time, I don't know if the code not running has anything to do with the change or not.
The new IMSL doesn't declare a name LOGFIL. mecej4's suggestion of using ONLY is a good idea, but if it doesn't help then there's another problem. Try doing a Build > Rebuild of your program and see if the problem remains.
Clay_N_
Sorry Steve Lionel,
In my last post I stated it compiled without errors, I meant it was built without errors. I am only trying to debug the code, not compile it.
The ONLY idea worked and got rid of all the build errors. I am currently trying to figure out why it is crashing while debugging. It might be completely unrelated to my previous problem though.
Thanks for your help.
Clay Norrbin
Error 6401 is a compile error, so you didn't see that just by rerunning the same executable. You had to recompile/rebuild the program to see that error - you didn't even get as far as creating an executable.
Clay_N_
With changing the statement from USE IMSL_LIBRARIES to USE IMSL_LIBRARIES, ONLY : N1RTY it goes all the way to an executable that I can run debug mode on. Again this means the error #6401 is gone which is good. I still do not understand why it works, or if it is going to create problems with the code.
Clay Norrbin
mecej4
Steve Lionel (Intel) wrote:
The new IMSL doesn't declare a name LOGFIL (in #4).
Steve, some distributions of IMSL-FNL-7 contain the variable LOGFIL in module files ARPACK_INCLUDES.mod and IMSL_LIBRARIES.mod, but not in NUMERICAL_LIBRARIES.mod. If this is also true of the recently released Intel distribution of FNL-7, changing "USE IMSL_LIBRARIES" to "USE NUMERICAL_LIBRARIES" in the example posted by Clay Norrbin may be a solution. It is not clear which version of IMSL it was that he used.
The IMSL7 we distribute does not incude a LOGFIL declaration.
Clay_N_
Hi Everyone,
The problem was resolved completely by switching back to IMSL 6.0.
Even with using "USE NUMERICAL_LIBRARIES" there were still some faults with running the code. However, changing from IMSL 7.0 to IMSL 6.0 fixed everything.
Thanks for your help,
Clay Norrbin
