29391 Discussions
Error #7011 after compiler change when including f90SQL
U_Chris
After a compiler change from Intel Visual Fortran Compiler 19.1.3.311 to Intel Fortran Compiler Classic 2021.10.0 I get the following error message:
error #7011: The module file for the module is obsolete.  Please recompile the module.   [F90SQLCONSTANTS]
      USE f90SQLConstants
All necessary module files concerning f90SQL can no longer be included. (F90SQL.mod, F90SQLconstants.mod, F90SQLstructures.mod)
Unfortunately I can't find any further information about the error message.
Maybe someone here has an idea how to get my project running again.
Thank you in advance for your support!
andrew_4619
You need to recompile those modules the old mod files are not compatible is what the message is saying.
EDIT I since noted the these are paid for libs, you need to speak to the vendor.....
U_Chris
Hi Andrew,
thanks for your reply. As far as I know, unfortunately, you can no longer contact the supplier.
Are there maybe conversion tools for the module files or is it possible to restore the compatibility by changing the compiler settings?
mecej4
As you can see in an older thread on a similar question, the company that developed F90SQL appears to be out of business. If you do not have a copy of the source code for F90SQL, you will have to keep using the older IFort version that is compatible with F90SQL, or look for alternative approaches to using ODBC data sources in Fortran programs.
andrew_4619
I don't know of any conversion tools or options, I do not think such things exist.  What are you trying to do BTW, it seems you are working with obsolete tools... Maybe there are other ways....
U_Chris
After a computer change I had to update some tools due to compatibility issues. Now I try to get all projects running again with as little effort as possible.
Unfortunately it doesn't seem to be that easy. I guess I have no other choice but to look around for alternatives.
Thanks for your comments anyway!
Steve_Lionel
U_Chris
Hi Steve,
thanks for the advice. Unfortunately the files are already the documents that are included in my project.
Steve_Lionel
The ZIP I attached there contains the source to the F90SQL module (at least the Lite version), so you can recompile it. There aren't many module incompatibilities - those that do exist are due to bugs in older compilers.
andrew_4619
I looked at that and concluded there was no source code... Wrong! There is no src folder but the sources are in the include folder  which I didn't look in.... Will the LIB file (dated yr 2000) be compatible to link with though?
U_Chris
Yes, the old lib is still compatible and can be used with the new module files!
U_Chris
Ohh, I guess I misunderstood your intention!
I have recompiled the sources from the directory, created new module files and included them in my project.
Now the program can be compiled without any errors!
Thank you all for your support. You have saved me a lot of work!
Steve_Lionel
Glad to hear it. Yes, old Intel Fortran objects/libs are compatible with newer compilers. This philosophy was carried over from DEC and might not apply to other compilers (such as Intel C++.)
