Error 7822 Work around
cptfisher
I received the following error when trying to compile a test program I wrote.  The purpose of the program is to output data from Aerodyn so I can compare it to the output from Aerodyn I receive from a matlab interface I wrote.  All the data is the same
ERROR 7822 : Variables containing ultimate allocatable array components are forbidden from appearing directly in input/output lists/
 write (2,*) MarkersResults
I just want the results from one time step from the aerodyn program written in a text file.  Is there any easy work around for this error?
Chris
You'll have to name the individual components you want to write in the I/O list, rather than the whole variable. Offhand, I don't know why the standard restricts this for output statements (I do for input), but perhaps it was intended to reduce complexity of implementation. The language provides a feature "user-defined derived type I/O" that can be used to specify how a derived type variable should be transmitted, but this is not yet supported by Intel Fortran.
cptfisher
Hi Steve, Thanks for your response. I tried your suggestion by listing the individual components as follows: write(2,*) MarkersResults(1,1), MarkersResults(2,1), ...etc and I receive the following error error #6410 This name as not been declared as an array or function "MarkersResults" ****************************************** I then tried to assign the MarkersResults to variables declared as real as follows: a = MarkersResults(1,1) b = MarkersResults(2,1) ......etc I would then try to write them into the output list but I received the same error as above. Is there any issue with using the derived data types in this manner?
Please show the declaration of MarkersResults (and its TYPE declaration if there is one). From the earlier message, MarkersResults is a derived type variable with components and not itself an array. You need to say something like MarkersResults%ComponentName(2,1) where ComponentName is the name of some array component of the derived type.
Johannes_Rieke
New Contributor III
Hi all, a quick search in NREL's aerodyn bib has shown no variable named MarkersResults but this definitions: [fortran] TYPE, PUBLIC :: Marker REAL(ReKi) :: Position(3) REAL(ReKi) :: Orientation(3,3) ! Direction Cosine Matrix (DCM) REAL(ReKi) :: TranslationVel(3) REAL(ReKi) :: RotationVel(3) END TYPE Marker TYPE, PUBLIC :: AllAeroMarkers TYPE(Marker), ALLOCATABLE :: Blade(:,:) TYPE(Marker), ALLOCATABLE :: Hub(:) TYPE(Marker), ALLOCATABLE :: RotorFurl(:) TYPE(Marker), ALLOCATABLE :: Nacelle(:) TYPE(Marker), ALLOCATABLE :: Tower(:) TYPE(Marker), ALLOCATABLE :: Tail(:) END TYPE AllAeroMarkers [/fortran] @Chris Is MarkersResults defined by yourself? If MarkersResults is of type Marker then this should work: [fortran] write(10,'(3f8.2)') MarkerDummy%Position(1:3) ! MarkerDummy is a scalar of type Marker [/fortran] for an AllAeroMarkers variable it is not totally clear to me how to address this. I guess: [fortran] type(AllAeroMarkers) :: AllAeroMarkersDummy ! allocate the components Blade, Hub, etc. write(10,'(3f8.2)') AllAeroMarkersDummy%Blade(1,1)%Position(1:3) ! is this correct? [/fortran] Best regards, Johannes
jimdempseyatthecove
type(Markers) :: MarkersResults(nMarkers) write(2,*) MarkersResults(iMarker)%Position, MarkersResults(iMarker)%Orientation, ... Note, if your MarkersResults is a two dimentional array then write(2,*) MarkersResults(iMarker,jMarker)%Position, MarkersResults(iMarker,jMarker)%Orientation, ... Jim Dempsey
cptfisher
I have it now, I was leaving out the components. Thanks for all your help.
cptfisher
Now that the above problems are sorted out and the program compiles w/out error, it does not seem to work. It creates the output file just fine (although its blank) but it seems like it is not calling for the calculation subroutine. The end of my code is below: **************************************************************** Write (2,*) MarkersResults%Blade(1,1)%Position, MarkersResults%Blade(2,1)%Position call ADInitialize(MarkersResults,ADOptions,TurbineComponents,ErrStat) close (2) Contains subroutine ADInitialize(MarkersResults,ADOptions,TurbineComponents,ErrStat) USE Aerodyn Type(Aeroconfig) :: TurbineComponents Type(AD_InitOptions) :: ADOptions Type(AllAeroMarkers) :: MarkersResults Integer :: ErrStat !Computational Routine Using Aerodyn Function AD_init ADOptions%ADInputFile = 'NRELOffshrBsline5MW_AeroDyn.ipt' ADOptions%OutRootName = 'OutPut' ADOptions%WrSumFile = .True. MarkersResults = AD_Init(ADOptions, TurbineComponents, ErrStat) return end subroutine ADInitialize end program ************************************************************* The subroutine uses the AD_Init function contained in Aerodyn. Is there some reason the program would be ignoring the "call" statement to the subroutine? There is no data being written to the output file because the program is not calling subroutine it appears. Everything seems to link ok when I build with VS2010.
You should step through the code with the debugger to see what is going on. The compiler is not "ignoring" the call. Whether the call is skipped due to program logic or the cause of the blank file is something else is what you need to find out. You may also want to verify that the file you're looking at is the correct one. For example, the default for files created while running in Visual Studio is the project folder - you may be assuming it is somewhere else.
cptfisher
Hi Steve, I ran it through the debugger and fixed the allocated part but I still ouput a blank data file. I'm pretty confident the logic must be wrong and the "call" statement is being skipped because the call to the initializing function should also produce a summary file which is never created. My entire program code is as follows: ********************************************* program test Use Aerodyn Implicit none !Variable Declarations TYPE(AD_InitOptions) :: ADOptions TYPE(AeroConfig) :: TurbineComponents TYPE(AllAeroMarkers) :: MarkersResults, InputMarkers Type(AllAeroLoads) :: LoadResults Type(AeroLoadsOptions) :: CurrentADOptions INTEGER :: ErrStat Real(ReKi) :: CurrentTime open (unit=2, file = "out.dat", action = "write") ! Place Data ! ! ! ! IF ( .NOT. ALLOCATED(TurbineComponents%Blade )) THEN ALLOCATE( TurbineComponents%Blade(3), STAT=ErrStat ) END IF TurbineComponents%Blade(1)%Position = [5.4343, 0.2258, 91.0480] TurbineComponents%Blade(1)%Orientation = reshape ( (/ -0.5726, 0.8199, 0.0030, -0.8158, -0.5693, -0.1020, -0.0819, -0.0608, 0.9948/), & (/3,3/)) TurbineComponents%Blade(1)%TranslationVel = [ 0.0723, -1.9573, -0.1987] TurbineComponents%Blade(1)%RotationVel = [ 1.2674, 0.0024, -0.0058] TurbineComponents%Blade(2)%Position = [ 5.4292, -0.8371, 88.6773] TurbineComponents%Blade(2)%Orientation = reshape ( (/ -0.5762, 0.8173, -0.0004, 0.4789, 0.3372, -0.8105, -0.6623, -0.4672, -0.5857/), & (/3,3/)) TurbineComponents%Blade(2)%TranslationVel = [ 0.0604, 1.0474, -1.5458] TurbineComponents%Blade(2)%RotationVel = [ 1.2674, 0.0024, -0.0058] TurbineComponents%Blade(3)%Position = [ 5.4260, 1.7475, 88.9422] TurbineComponents%Blade(3)%Orientation = reshape ( (/ -0.5720, 0.8203, -0.0026, 0.3342, 0.2359, 0.9125, 0.7491, 0.5211, -0.4091/), & (/3,3/)) TurbineComponents%Blade(3)%TranslationVel = [ 0.0761, 0.7117, 1.7300 ] TurbineComponents%Blade(3)%RotationVel = [ 1.2674, 0.0024, -0.0058] TurbineComponents%BladeLength = 61.5000 TurbineComponents%Hub%Position = [5.4299, 0.3787, 89.5558] TurbineComponents%Hub%Orientation = reshape ( (/0.0012, -0.9948, -0.1020, 1.0000, 0.0015, -0.0028, 0.0030, -0.1020, 0.9948/), & (/3,3/)) TurbineComponents%Hub%TranslationVel = [0.0696, -0.0661, -0.0048] TurbineComponents%Hub%RotationVel = [1.2674, 0.0024, -0.0058] TurbineComponents%RotorFurl%Position = [5.4299, 0.3787, 89.5558] TurbineComponents%RotorFurl%Orientation = reshape ( (/0.0015, -1.0000, 0.0026, 1.0000, 0.0015, -0.0028, 0.0028, 0.0026, 1.0000/), & (/3,3/)) TurbineComponents%RotorFurl%TranslationVel = [0.0696, -0.0661, -0.0048] TurbineComponents%RotorFurl%RotationVel = [0.0003, 0.0005, -0.0022] TurbineComponents%Nacelle%Position = [0.4102, 0.3676, 89.3628] TurbineComponents%Nacelle%Orientation = reshape ( (/0.0015, -1.0000, 0.0026, 1.0000, 0.0015, -0.0028, 0.0028, 0.0026, 1.0000/), & (/3,3/)) TurbineComponents%Nacelle%TranslationVel = [ 0.0703, -0.0511, -0.0016] TurbineComponents%Nacelle%RotationVel = [ 0.0003, 0.0005, -0.0022] TurbineComponents%Tower%Position = [ 0.1578, 0.1396, 0.0081] TurbineComponents%Tower%Orientation = reshape ( (/ 0.0015, -1.0000, 0.0026, 1.0000, 0.0015, -0.0028, 0.0028, 0.0026, 1.0000/), & (/3,3/)) TurbineComponents%Tower%TranslationVel = [ 0.0277, -0.0241, -0.0025] TurbineComponents%Tower%RotationVel = [ 0.0003, 0.0005, -0.0022] call ADInitialize(MarkersResults,ADOptions,TurbineComponents,ErrStat) Write (2,*) MarkersResults%Blade(1,1)%Position, MarkersResults%Blade(2,1)%Position, MarkersResults%Blade(3,1)%Position deallocate (TurbineComponents%Blade ) deallocate ( MarkersResults%Blade ) Contains subroutine ADInitialize(MarkersResults,ADOptions,TurbineComponents,ErrStat) USE Aerodyn Type(Aeroconfig) :: TurbineComponents Type(AD_InitOptions) :: ADOptions Type(AllAeroMarkers) :: MarkersResults Integer :: ErrStat !Computational Routine Using Aerodyn Function AD_init ADOptions%ADInputFile = 'NRELOffshrBsline5MW_AeroDyn.ipt' ADOptions%OutRootName = 'OutPut' ADOptions%WrSumFile = .True. MarkersResults = AD_Init(ADOptions, TurbineComponents, ErrStat) return end subroutine ADInitialize end program test *********************************************** Is there anything obviously wrong with the program that would be causing this problem?
Well, this isn't the whole program... I wonder if you're looking at the wrong output file. You say you "ran it through the debugger" but did you step into the call and see what got executed? Two things I can think of. 1) You're looking in the wrong folder for the output file - as an experiment, try giving it a complete path. 2) Part of this program is in a DLL and you didn't build the executable to link to the DLL form of the run-time libraries.
