29249 Discussions
Error #7977: The type of the function reference does not match the type of the function
史_建鑫
Hi, I have a function that got the error #7977 when i compiled it. This code is to get the available physical memory during the program run and the compile platform is win32
[fortran]
function int4to8(src) result(des)
    use IFWINTY
    implicit none
    type(T_LARGE_INTEGERX) :: src
    integer(kind=8) :: des
    integer :: i
    integer :: tmp
    do i=0,31
        write(*,*) BTEST (src%LowPart,i)
        if(BTEST (src%LowPart,i) == .TRUE. ) then
            des = IBSET (des,i)
        end if
        if(BTEST (src%HighPart,i) ==.TRUE.) then
            des = IBSET (des,i+32)
        end if
    end do
end function int4to8
program GetSystemMemory
    use KERNEL32
    use IFWINTY
    type(T_MEMORYSTATUSEX) :: mymem
    logical :: switch
    type(T_LARGE_INTEGERX) :: xixi
    integer(kind=8) :: res
    MYMem%dwLength = sizeof(MYMem)
    switch = GlobalMemoryStatusEx(MYMem)
    xixi = MYMem%ullAvailPhys
    res = int4to8(xixi)
    write(*,*) "ullAvailPhys", res/1024
[/fortran]
Thank you for your help!
Steven_L_Intel1
The error message is exactly on target. You declared the result of int4to8 to be integer(8), but didn't declare it that way in the main program, so it was integer(4) there. If you had made the function a contained procedure or module procedure, this would not have been an issue.
