29653 Discussions
Error: Command .../ifort failed with exit code 1
Allan_Leuan
I am a new user of Xcode and intel fortran. I encounter the following problem and hope to get some help! Thanks!!
I tried to build and run the following simple fortran 90 code:
subroutine hello(a,b)
implicit none
real,intent(out):: a
real,intent(in):: b
a = b
end subroutine
However, the Xcode gave me an error message as:
"Command /Developer/usr/local/bin/ifort-11.1-base/bin/intel64/ifort failed with exit code 1"
As it provides no further details, I have no clue about what the error is about... Thanks!!
Udit_P_Intel
This looks like a legal program. If Xcode is giving a problem, try something executable like hello world to make sure it compiles and runs.
I just compiled your program with an Intel64 machine in 11.1 version of the compiler and got an object file without any error.
Did you check that an object file indeed wasn't generated?
Please continue discussion in the other thread.
