Print and Read on a line
anishtain4
I want to print something on the screen and then read something while the cursor is at the same line, how should I do this?
Robert_van_Amerongen
New Contributor III
Maybe you can use something like
WRITE(*,'("Give a value =>: ")',ADVANCE='NO')
READ(*,*) value
Robert
New Contributor III
READ(*,*) value
Robert
No, that doesn't work - at least in our implementation. You have to use an extension:
write (*,'($,A)') "Number please: "
read (*,*) number
write (*,*) number, " is your lucky number"
end
There is a feature request in to make the version using non-advancing I/O work as desired here. The standard doesn't require it, but some other implementations do it.
Arjen_Markus
I thought it would work with F2003's flush statement (and output_unit from iso_fortran_env),
but it doesn't. The flush statement "flush( output_unit )"causes the message that unit 6 is not
connected.
Arjen
New Contributor III
Steve,
I am a little confused by your remark. The "ADVANCE" specifier works fine and is a FORTRAN feature (see Metcalf , par. 9.11, Non-advancing I/O)
[fortran]  PROGRAM adv
  IMPLICIT none
  REAL :: value
  WRITE(*,'("Enter a value =>: ")', ADVANCE='NO')
  READ(*,*) value
  WRITE(*,*) "You give the value:", value
  WRITE(*,'($,A)') "Enter a value =>: "
  READ(*,*) value
  STOP
  END PROGRAM adv  [/fortran]
Or do I miss the essence of your remark?
Robert
Well, no, I made an error. I was confusing this with the issue where people who want to use non-advancing I/O for a progress bar can't get it working on Intel Fortran. You are correct that it works fine for the "prompt" case. Thanks for picking up on that and I apologize for the mistake.
anishtain4
Thanks you both. both methods works fine
