29285 Discussions
Error LNK 2001 while makin c dll for usin in java
jyotikiran
Hi frens,
i am developin an application in java which requires me to use some of the apis which r developed in c.
Now while i complile the c file for usin in java it gets compiled.It also gets executed if i use a main in the program.
But when i try creatin dll for the same program without the main giving the Cl/LD filename.c in the pre compile options of the Microsoft Visual C++ editor it gives me the Lnk2001 Error sayin
IstTest1.obj : error LNK2001: unresolved external symbol _ETUnLink
IstTest1.obj : error LNK2001: unresolved external symbol _ETSocketLink
N so on.
The above functions r declared ina header et1000.h which i have already included in my program.
Also i have included all the other necessory files.
I have also included the necessary lib file n linked it by puttin it in the object/options of the project /settings options of the Microsoft Editor.
Pls tell me wht could b wrong.
Its very urgent.
I really dont understand while executing the same program with main it gets executes fine by includin the header files.
But when i remove the main for makin the dll to b used in the java program it gives me the LNK error.
PLs help....
I'm stucked
This forum is for users of, and questions relating to, Intel Fortran for Windows and Compaq Visual Fortran. I don't see that you're using either of these products - are you?
Steve
