29648 Discussions
Error LNK1104 in compiling an opensource software with Intel Fortran Compiler
Gao__Wu
Hi all,
I would like to compile an opensource software (which is called “Cantera”) with Intel Fortran compilers to get its Fortran interface, but I encountered a problem that the Cantera's developers did not meet.
Here's my basic set up and installation directories:
  • Windows 10 64-bit
  • Visual Studio 2010 (C:\Program Files (x86)\Microsoft Visual Studio 10.0)
  • Intel Parallel Studio XE 2016 (C:\Program Files (x86)\IntelSWTools)
  • Python 3.7.4 (C:\Python37)
  • SCons 3.1.1 (C:\Python37\Lib\site-packages\scons)
  • Boost 1.70.0 (C:\Users\Wu\boost)
  • Cantera 2.4.0 (source codes that need to be compiled; C:\Users\Wu\cantera)
The Intel Fortran compiler “ifort.exe” has been added to the Path of the system Environment Variables by ‘C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.4.246\windows\bin\intel64’ (it also can be written as FORTRAN = ‘C:\\PROGRA~2\\IntelSWTools\\compilers_and_libraries_2016.4.246\\windows\\bin\\intel64\\ifort.exe’ in a cantera.conf file which scons can read), then ‘scons build’ command was input in the Windows PowerShell to run the compiling. However, compiling halts due to following error:
PS C:\Users\Wu\cantera> scons build
scons: Reading SConscript files ...
INFO: SCons is using the following Python interpreter: C:\Python37\python.exe
INFO: Compiling with MSVC 10.0
INFO: Compiling for architecture: amd64
INFO: Compiling using the following toolchain(s): ['default']
Configuration variables read from 'cantera.conf' and command line:
    msvc_version = '10.0'
    f90_interface = 'y'
    boost_inc_dir = 'C:\\Users\\Wu\\boost\\boost_1_70_0'
Checking for C++ header file cmath... yes
Checking for C++ header file fmt/ostream.h... no
INFO: Using private installation of fmt library.
INFO: Could not find version of fmt
Checking for C++ header file yaml-cpp/yaml.h... no
INFO: Using private installation of yaml-cpp library.
Checking for C++ header file gtest/gtest.h... no
Checking for C++ header file gmock/gmock.h... no
INFO: Using Googletest from Git submodule
Checking for C++ header file Eigen/Dense... no
INFO: Using private installation of Eigen.
INFO: Found Eigen version 3.3.4
Checking whether __GLIBCXX__ is declared... no
Checking whether _LIBCPP_VERSION is declared... no
Checking whether __clang__ is declared... no
INFO: Found Boost version 1.70
Checking whether boost::core::demangle is declared... yes
Checking for CVodeCreate(CV_BDF, CV_NEWTON) in C++ library sundials_cvodes... no
Checking for CVodeCreate(CV_BDF) in C++ library sundials_cvodes... no
Checking for double x; log(x) in C library None... yes
INFO: Using private installation of Sundials version 3.1.
WARNING: Unable to use 'ifort' to compile the Fortran interface. See config.log for details.
ERROR: Couldn't find a suitable Fortran compiler to build the Fortran 90 interface.
In the config.log, this message can be found:
.sconf_temp\conftest_16.f90 <-
  |program main
  |   write(*,'(a)') 'Hello, world!'
  |end program main
ifort -o .sconf_temp\conftest_16.obj -c -O3 .sconf_temp\conftest_16.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.4.246 Build 20160811
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
link /nologo /DEBUG /OUT:.sconf_temp\conftest_16.exe .sconf_temp\conftest_16.obj
LINK : fatal error LNK1104: cannot open file “ifconsol.lib”
I’ve tested the Intel Fortran compiler by adding this “hello, world” program (as in conftest_16.f90) to a fold called “testf” on the desktop and compiled it with the Intel Compiler windows prompt, a corresponding .obj file can be successfully generated with no such LINK error.
C:\Program Files (x86)\IntelSWTools>cd C:\Users\Wu\Desktop\testf
C:\Users\Wu\Desktop\testf>ifort /c conftest_16.f90
Is there some setup I am missing so that this compiling process can’t proceed? Cantera’s developers have successful experience compiling the Cantera Fortran interface using Intel compilers on Linux but no such experience on Windows. I have been stuck with this problem for a couple of weeks. Any help and advice are much appreciated.
Kind regards,
Wu
Gao__Wu
Hi all,
This problem has been solved.
The solution is as follows:
Open the Visual Studio 2010 x64 Command Prompt from the Start menu, and run the Intel compilervars.bat file first. For example, like this:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.4.246\windows\bin\compilervars.bat" intel64
In the same prompt then change the directory to wherever the Cantera source is and then run scons build. For example, like this:
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC>cd C:\Users\cantera
C:\Users\cantera>scons build
Kind regards,
Wu
