29606 Discussions
Error LNK2019 when using Fortran Intrinsic Functions
lls121
I just started using Intel Visual Fortran Compiler for Windows, and I am trying to set up a solution in Visual Studio 2010 that contains a Fortran Static Library project and a C++ project. I can access my Fortran subroutines and functions through the C++ project without any issues, but when I include any Fortran intrinsic functions in my Fortran code, I get a LNK2019 error.
For example, I created a Fortran function, FR,that calls the SQRT function. The Fortran project builds fine, but when I callFRin my C++ code, I get an error LNK2019: unresolved external symbol _SQRT referenced in function _FR. What do I need to include in my project so that I can use these functions?
Thanks for the help.
So you didn't see this warning?
FortranTest\FortranTest\test.f(11): warning #7319: This argument's data type is incompatible with this intrinsic procedure; procedure assumed EXTERNAL. [SQRT]
In subroutine FSROOT, you have a call to SQRT(N). N is not declared, so, by the rules of Fortran, it is implicitly INTEGER. (Variables starting with I through N are integer, all others are real. Hence the Fortran joke: "God is real, unless declared integer.")
SQRT is not defined for the integer type, so you get the warning. The compiler then assumes you mean some external routine SQRT which you didn't provide.
Assuming that you want to take the square root of the value of N, you will have to write it as:
FSROOT = SQRT(REAL(N))
The REAL() intrinsic converts the argument to the REAL datatype.
By the way, at least in this example, you don't need the ATTRIBUTES DLLEXPORT as you are building a static library. It does no harm.
mecej4
The C/C++ compiler driver is treating the .OBJ files that the Fortran produced as if they were also C/C++ compiler-produced.
You may specify the appropriate Fortran library that contains the intrinsic functions to be used when linking.
lls121
Thanks for the response, mecej4. Could you be a little more specific regarding how to do this? Where would I specify the appropriate Fortran library within Visual Studio 2010?
lls121
Hi Steve,
I have followed these instructions, but I still get this error. Any ideas?
Are you getting any warnings during the Fortran compilation? That you get a reference to _SQRT suggests to me that you're also seeing a warning that the arguments to an intrinsic don't match a supported signature and hence an external reference is used.
lls121
I am not getting any warnings when I compile the Fortran static library. I just get these two errors in the C++ project:
error LNK1120: 1 unresolved externals
However, if I make a Fortran dynamic-link library, I receive these errors during the Fortran compilation instead of the C++ compilation.
Would you please attach the Fortran project, including sources, as a ZIP file? Or at least a sample project that shows this error?
lls121
I have attached my project. Thanks again for the help. I really appreciate it.
I am completely new to Fortran, so it could easily be a programming issue.
lls121
Thanks for the help Steve!
