29430 Discussions
Error: The type of the actual argument differs from the type of the dummy argument
pierangelo_f_
With the following source code:
subroutine
pippo( n )
implicit none
interface
subroutine pluto( row )
type array
integer(4), dimension(:), pointer :: col
end type array
type(array), dimension(:), pointer :: row
end subroutine pluto
end interface
integer, intent(in) :: n
integer :: i, ierr
type array
end type array
allocate( row(n), stat = ierr )
if( ierr.gt.0 ) stop 'Allocation error'
do i=1,n
allocate(row(i)%col(i), stat=ierr)
row(i)%col = 0
enddo
call pluto( row )
end subroutine
pippo
I get the ERROR code in the subject.
I don't understand why.
Because the actual and dummy arguments are not of "the same declared type". It does not matter if the names and components of the types are the same.
Check out my blog post on IMPORT for a convenient solution.
mathelon
I work with an old fortran code written in the eightys.
With compaq visual fortran, the following extract of the code just produced a warning :
call etunt_k_elem(iregim(n),npi(n),tabt(ipt(1)),tabt(ipt22),
x neq(n),tabt(ipt(4)),tabt(ipt(5)),tabt(ipt20),tabt(ipt21),
x pk0(1,1,n),itrain(1,n),i,vt,tabt(ipt(25)),pkt1,
x tabt(ipt24),tabt(ipt(26)),param0(1,n),tabt(ipt27),iregimold(n))
subroutine etunt_k_elem(iregim,npi,xint,cint,
x neq,lnod,xl,cl,cel,pk0,itrain,itrac,vtn,xlold,pkt,celi,
x lnod0,param0,celold,iregimold)
c
c--- calcul de la solution aux noeuds mobiles partir des solutions du pas de temps prcdent
c
include 'device.ncl'
include 'trans.ncl'
dimension xint(*),cint(*),lnod(*),xl(*),cl(*),cel(*),
x pk0(2,2),itrain(2),vtn(*),xlold(*),pkt(2,*),celi(*),
x lnod0(*),param0(*),celold(*)
The type is implicit (I know it's bad but the whole code is written like this). As a consequence, I think there is a problem with tabt(ipt(4)) wich is a real and lnod which is an integer.
With Intel visual fortran this problem product an error... I don't have the time to modify all the structure of the code. How can I interfer on the project settings to treat this pb as a warning ?
Thanks for your help
You do understand that this mismatch can give you incorrect results?
Since you refer to a project, my guess is that the project default of interface checking is enabled. In the project settings, Diagnostics page, turn off "Generate interface blocks" and "Check routine interfaces".
jimdempseyatthecove
Felotti,
Below is a reworked example that works.
**** However, when compiling with Check Interfaces an error message is returned
Turning off Check Interfaces produces a runable program. Revise thecode to suit your needs and please submit a report to premier support.
*** Note, the test program does not return the allocations
Jim Dempsey
module
foo
type array
integer(4), pointer :: col(:)
end type array
type arrayPointer
type(array), pointer :: row(:)
end type arrayPointer
end module
foo
program
Test
implicit none
interface
subroutine pippo( n )
end subroutine pippo
end interface
call pippo(10)
end
program Test
subroutine
pluto( ap )
use foo
implicit none
type(arrayPointer) :: ap
integer :: r, c
do r=1,size(ap%row)
do c=1,size(ap%row%col)
&nb sp;write(*,*) r,c, ap%row%col(c)
end do
end do
end subroutine
pluto
subroutine
pippo( n )
use foo
implicit none
interface
subroutine pluto( ap )
use foo
implicit none
end interface
integer :: i, ierr, j
allocate( ap%row(n), stat = ierr )
do i=1,n
allocate(ap%row(i)%col(i), stat=ierr)
do j=1,i
ap%row(i)%col(j) = i*100+j
end do
enddo
call pluto( ap )
end subroutine
pippo
