Error casing nun values
craneboba
Compiler
Intel(R) Visual Fortran Compiler XE 13.0.0.089 [IA-32]...
Only turn on optimisation
When doing
      logical*4 FUNCTION COMPUTE_REGRESSION2(NY)
      real*8     R8
      integer*8  NY
c
      R8=NY             ! При for some values of NY-  R8=NaN
Same code never gives nun, if
added if after
R8=NY
      if (isnan(r8)) then;
            call append(' r8=Nan');  call dos_line_wait();
      end if
Arjen_Markus
Can you provide a complete program that shows the problem, including the compiler options that are required for reproducing it? Now we need to guess at a few things, which makes it quite difficult.
craneboba
Thanks for fast answer Arjen_Markus
Failed to isolate error. That is, I cannot write
a short piece of code, when executed, the assignment operator:
Var_Real_8 = Var_Integer_8
would return the value Var_Real_8 = NaN, under normal
value Var_Integer_8.
Compilation options
/nologo /debug:full /MP /Od /QaxSSE3 /QxSSE3 /Qparallel
/assume:buffered_io /I"O:\_WinABD\LB" /I"O:\_WinABD\inc" /arch:SSE3
/extend_source:132 /Qdiag-error-limit:60 /debug-parameters:all
/warn:declarations /warn:unused /warn:ignore_loc /warn:truncated_source
/warn:interfaces /assume:byterecl /Qtrapuv /Qzero /Qfp-speculation=fast
/module:"O:\Temp/" /object:"O:\Temp/" /Fd"O:\_WinABD\_Debug\vc90.pdb"
/traceback /check:bounds /check:uninit /libs:static /threads /dbglibs /c
There are /nologo /debug:full /MP /Od /QaxSSE3 /QxSSE3 /Qparallel
There are certain conditions, when we observed
The error appears not so often when1) The program must have numerous calls to the DATE_AND_TIME function2) The program must consist of several files3) Optimization for speed is enabled
So many  transformations Var_Real_8 = Var_Integer_8
 Give correct values , when suddenly some call gives nun
We are  calling DATE_AND_TIME inside a computation loop to timed
time of its work and print% of completion once a second.
If the cycle is short (hundreds of thousands of steps), then everything works correctly.
But if the loop is executed millions of times, then at some point
operator
  Calling DATE_AND_TIME must be not in the same block ( fortran file), were we   do transformation
We do some random time series generations, using standart functions for this.
We use  DATE_AND_TIME  for generating time coordinate.
In the result we get big time serises.
When we plot it later we see, that some points from hundreds
has no value . We tested it on 26 different computes
with windows 7 and windows 10 (64) and often observed it.
When /Qfp-speculation=fast
Bug does not exists.
Best wishes.
Vladimir Zhuravlev , MVP 2006-2017,PHD
www.foxclub.ru domain owner
