29640 Discussions
Error code: 1603 - Windows Installer
GS76
To whom it may concern:
I would appreciate assistance.
I have to install Intel Parallel Studio XE 2016 with Visual Studio 2015 in order to be able to compile Fortran sub-routines for MSC Marc 2017.1. This version of MSC Marc does not allow newer versions to be installed.
I believe I have installed MS Visual Studio 2015 as required. Please see image attached and text file of installed list. However, when I try to install the above version of Intel, I receive the message as seen in this attached screen shot. I have attached the log file as a zipped file.
I am running Windows 7 Professional 64-bit Service Pack 1.
Any assistance would be most welcome.
Thank you.
Gary
Dortkasli__Kerem
Hello Gary,
I have almost the same problem with you. (doing same things for msc marc 2018.1, same as you)
I installed visual studio 2015 correctly ı believe, than I tried to install intel paralle studio xe 201t however It gave error 1603.
Did you find a solution to this problem?
Thank you,
Kerem.
