Hello friends!
I am receiving a warning message of overflow(see attached) when trying to convert character to real.
This is the simple piece of code
Hm, also not correct. I will encourage you to have a look into the help: https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-format-specifications
What you have done in 1) is to write the real number as 5 digit field to a 4 character long character variable. Does not match, isn't it.Try something like this:
program test implicit none real(kind=1.0) :: num_nlevels character(len=100) :: nLevels write(nLevels,'(F5.0)') num_nlevels write(*,'(a)') trim(nLevels) ! or write(nLevels,'(I0)') nint(num_nlevels) write(*,'(a)') trim(nLevels) end program test
ps: Arjen was faster ;-)
Hm, you have defined num_levels as a real and you are using an integer format to read it from the character string. There is a discrepancy here ;).
Thanks Arjen!
My fault, lack of attention, sorry!!!! I made a mistake copying the code.
I tried both; define "num_nLevels" as integer and real. In both cases it is giving me back the same error (output statement overflows record)
1)
Well, for case 1 you are trying to put 5 characters into a character string of length 4. And depending on the actual value of num_levels (you do not show it), this sting length might not be enough in case 2 either.
Why not try with a much larger character length? 20 or 40, say. Just to see what happens.
Thank you for your time and your effort. These format problems are annoying issues difficult to handle. Johannes, thank you for the link and the code.
Hello again!
I am sadly stuck in the middle of nowhere and I don't know what else I can try. I am using VisualStudio for Fortran developings. I can not attach a dat file, so I captured screen.
Please someone that tells me why trying write(strlevels,'(F7.0)') nlevels does not work.
THANK YOU!!
You want READ and not WRITE if you want to convert the character representation into a REAL.
Once again Doctor, thank you. Programming in Fortran makes me feel I do not know anything. Thanks again.
Hi, in case you will like to read and parse *.JSON files
(open(2,file='C:\file.JSON',status='unknown'),
you might like to use a pure Fortran library written by Jacob Williams:
https://github.com/jacobwilliams/json-fortran
To take advantage from this lib, you might need to enhance your Fortran base skills.
