Error executing .exe file
Juan_David_V_
Hello.
I have a fortran project. When I run it in visual studio everything works fine but when I try to run the correspond .exe file I get this error "C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\ia64\libmmd.dll is not desgined to run on windows".
I have looked for a solution but I found nothing.
Thanks for any help.
I think you have PATH set up incorrectly to include IA64 compiler support DLLs (something we have not provided since version 11.0) You should edit the system PATH environment variable to remove any folders with IA64 in their name.
jimdempseyatthecove
IA64 is the build for Itanium processors. You want to build for x64 (Intel64) processors.
Jim Dempsey
Juan_David_V_
I changed the plataform to x64 but I get this new error: "C:\Program Files (x86)\Common Files\Intel\Shared Files\fortran\bin\ia64\libifcoremmd.dll is not desgined to run on windows".
Juan_David_V_
Thnaks a lot.
I had installed the intel fortran libraries version 11.0. I deleted it and then installed the version 15.0 and problem solved!
