Error in Fortran Derived Type
mic_esp96
Good morning devs, I am building a derived type to kind of "simulate" a dinamic-rank array. However this is just the very first version of this.
Here it is the code:
module MyBisp
   implicit none
   type bvals
      real, allocatable :: vals(:)  !column values
   end type
   type Bisp
      type (bvals), allocatable :: bvals(:)  !row values.
   end type Bisp
   type B3D
      type (Bisp), allocatable :: ndims(:,:,:)
      contains
      procedure :: init => init_dims3
      procedure :: all => all_bisp
   end type B3D
   type PSD2D
      type (bvals), allocatable :: ndims(:,:)
      contains
      procedure :: init => init_dims2
      procedure :: all => all_psd
   end type PSD2D
   contains
   subroutine init_dims3(self,n)
      implicit none
      class (B3D), intent(inout) :: self
      integer, intent(in) :: n
      integer :: istat
      allocate(self%ndims(n,n,n),stat=istat)
      if (istat.ne.0) call errall('B3D_init_dims3',istat,'b%ndims')
      ! self%ndims(:,:,:)  = 0.d0
   end subroutine
   subroutine init_dims2(self,n)
      implicit none
      class (PSD2D), intent(inout) :: self
      integer :: istat
      allocate(self%ndims(n,n),stat=istat)
      if (istat.ne.0) call errall('PSD2D_init_dims2',istat,'psd%ndims')
      ! self%ndims(:,:)  = 0.d0
   end subroutine
   subroutine all_bisp(self,i,j,k,n)
      implicit none
      integer, intent(in) :: i,j,k,n
      integer :: istat
      if (.not.allocated(self%ndims)) write(*,'(a)'), '  ERROR (b3d): "ndims" not allocated !'
      allocate(self%ndims(i,j,k)%bvals(n)%vals(n),stat=istat)
      if (istat.ne.0) call errall('B3D_all_bisp',istat,'b%ndims%bvals%vals')
      ! self%ndims(:,:,:)%bvals(:)%nvals(:)  = 0.d0
   end subroutine
   subroutine all_psd(self,i,j,n)
      implicit none
      integer, intent(in) :: i,j,n
      integer :: istat
      if (.not.allocated(self%ndims)) write(*,'(a)'), '  ERROR (psd2d): "ndims" not allocated !'
      allocate(self%ndims(i,j)%vals(n),stat=istat)
      if (istat.ne.0) call errall('PSD2D_all_psd',istat,'psd%ndims%vals')
      ! self%ndims(:,:)%bvals(:)%nvals(:)  = 0.d0
   end subroutine
end module
which is then called within a subroutine of the main program:
type (PSD2D) :: psdfb,psdfmb,psdrmb,psdrb
type (B3D)   :: bfb,bfmb,brmb,brb
   if (bsaExtended.eq.1) then
      itmp=sbvdat_NDOF
   else
      itmp=crenum_NUMNP
   end if
   ! INIT BISPs & PSDs
   psdfb%init(itmp)
   psdrb%init(itmp)
   bfb%init(itmp)
   brb%init(itmp)
   psdfmb%init(stabil_NVAP)
   psdrmb%init(stabil_NVAP)
   bfmb%init(stabil_NVAP)
   brmb%init(stabil_NVAP)
   do i=1,stabil_NVAP
      do j=1,stabil_NVAP
         psdfmb%all(i,j,bsa_numfrqs)
         psdrmb%all(i,j,bsa_numfrqs)
         do k=1,stabil_NVAP
            bfmb%all(i,j,k,bsa_numfrqs)
            brmb%all(i,j,k,bsa_numfrqs)
         enddo
      enddo
   enddo
   do i=1,itmp
      do j=1,itmp
         psdfb%all(i,j,bsa_numfrqs)
         psdrb%all(i,j,bsa_numfrqs)
         do k=1,itmp
            bfb%all(i,j,k,bsa_numfrqs)
            brb%all(i,j,k,bsa_numfrqs)
         enddo
      enddo
   enddo
I'm facing some errors, which I cannot well understand.
In the version you see here attached, I get the following errror:
error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: % . = =>
at each line where I call both procedures INIT and ALL.
If I add ALLOCATABLE in the 4 module's subroutines CLASS declaration, I also have:
 error #8263: The passed-object dummy argument must be a scalar, nonpointer, nonallocatable dummy data object.   [SELF]
I cannot see what I am doing wrong..
Thank to everyone.
mecej4
You seem to have overlooked the fact that in Fortran, unlike in C, etc., calling a procedure requires the word CALL to come before the procedure name and argument list.
mecej4
mic_esp96
Thanks @mecej4 , I supposed that that kind of calling could have had a different syntax, while it is not the case (thinking that the "call" word was hidden behind the "%" syntax..). Thanks, now it works.
