Error in IMSL routine QD2VL
Intel_C_Intel
I've tried to run the IMSL routine QD2VL sample problem which appears on page 698 of the MathV1.pdf file (using IVF Pro for Windows version 9.1.032). The build had no errors, but running it yielded the following output. Source is included too.
I'd appreciate your help in resolving this issue.
Yair
================= output========================
D:Fortran Projects rial1 rial1Debug>trial1
X Y F(X,Y) QD2VL DIF
*** TERMINAL ERROR 1 from QD2VL. The number of data points in the X
*** direction must be at least 3 while NXDATA = 0 is given.
*** TERMINAL ERROR 2 from QD2VL. The number of data points in the Y
*** direction must be at least 3 while NYDATA = 0 is given.
================ source ========================
include 'link_f90_static.h'
INTEGER LDF, NXDATA, NYDATA
PARAMETER (NXDATA=21, NYDATA=42, LDF=NXDATA)
INTEGER I, J, NOUT
REAL F, FDATA(LDF,NYDATA), FLOAT, PI, Q, &
SIN, X, XDATA(NXDATA), Y, YDATA(NYDATA)
INTRINSIC FLOAT, SIN
! Define function
F(X,Y) = SIN(X+Y)
! Set up X-grid
DO 10 I=1, NXDATA
XDATA(I) = FLOAT(I-1)/FLOAT(NXDATA-1)
10 CONTINUE
! Set up Y-grid
DO 20 I=1, NYDATA
YDATA(I) = FLOAT(I-1)/FLOAT(NYDATA-1)
20 CONTINUE
! Evaluate function on grid
DO 30 I=1, NXDATA
DO 30 J=1, NYDATA
FDATA(I,J) = F(XDATA(I),YDATA(J))
30 CONTINUE
! Get output unit number
CALL UMACH (2, NOUT)
! Write heading
WRITE (NOUT,99999)
! Get value for PI and set X and Y
PI = CONST('PI')
X = PI/4.0
Y = PI/4.0
! Evaluate quadratic at (X,Y)
Q = QD2VL(X,Y, XDATA, YDATA,FDATA)
! Print results
WRITE (NOUT,'(5F12.4)') X, Y, F(X,Y), Q, (Q-F(X,Y))
99999 FORMAT (10X, 'X', 11X, 'Y', 7X, 'F(X,Y)', 7X, 'QD2VL', 9X,&
'DIF')
END
You did not faithfully copy the source in the manual. In particular, you omitted the crucial first line:
USE IMSL_LIBRARIES
The INCLUDE is not a substitute for that. If you add the USE line (after the INCLUDE is fine), then it works as described.
All of the documented examples use the "Fortran 90" style calls to the IMSL routines which require that you have the appropriate USE line(s) as listed.
Intel_C_Intel
You're right of course, my bad.
Thanks a lot!
