29650 Discussions
Error in appending additional command line options
Steefel__Carl
Trying to link statically with all libraries, including OpenMp. I append the following commands in the Project --> Fortran --> Command Line drop down in Intel Visual Fortran 11.1 (using Microsoft Visual Studio 2008):
/Qopenmp-link:static /Qopenmp /MT
and I get the warning during the final link:
1>Link: warning #10006: ignoring unknown option '/Qopenmp-link:static'
1>Link: warning #10006: ignoring unknown option '/Qopenmp'
1>LINK : warning LNK4044: unrecognized option '/MT'; ignored
which presumably explains why the static link doesn't work. Why aren't these commands taken when provided as Additional Options in Command Line inside the IDE environment????
The error messages indicate that you added these to the Linker > Command Line property page rather than the Fortran > Command Line page. You should not need to specify either /Qopenmp nor /MT as command line options as both of those are available as regular properties (Language page for /Qopenmp and Libraries page for /MT, which is the same as the default of /libs:static /threads.)
Steefel__Carl
OK, I got rid of the error message. However, the code still does not create a fully static library. It is still looking for libiomp5md.dll (the dynamic version)...
Are you building a library or an executable? If a library, then you're dependent on what the executable's build options are - if it is compiled /Qopenmp, it will look for libiomp5md.dll by default. There's no way to control that from a static library.
Steefel__Carl
First I build the library, then the executable with a link to that library. So perhaps the library should not be built with /Qopenmp??
Anyway, I never had this problem before--I could always build a fully static executable...
In version 11.0, we changed the default for the OpenMP library to use the DLL form. You can still build a fully static executable if you use /Qopenmp-link:static when building the executable. Actually, what you set here for a static library project is likely ignored since those default to "Disable OBJCOMMENT Library Names in Object: Yes".
