Error in arguments of MOVE_ALLOC
A__Valle
Dear all,
When compiling the following code, I get an error that the argument of MOVE_ALLOC shall be an allocatable object:
error #8195: The argument to the MOVE_ALLOC intrinsic subroutine shall be an allocatable object.   [MOVE_ALLOC]
In this example both arguments are allocatable:
[fortran]FUNCTION Test_MoveAllocFunc(newSize) RESULT(idPS) !{
   !** HEADER VARIABLES/ARGUMENTS
    IMPLICIT NONE
    INTEGER :: newSize
  !** RETURN VARIABLE
    INTEGER :: idPS
  !** LOCAL VARIABLES
    TYPE(PSType), POINTER :: TempPS(:)
    TYPE (PSType), POINTER :: UI_PS(:)=>null()
    TempPS=>null()
    ALLOCATE(TempPS(-1:newSize-1), SOURCE=UI_PS)
    DEALLOCATE(UI_PS)
    ALLOCATE(UI_PS(-1:newSize))
    CALL MOVE_ALLOC(TempPS, UI_PS)
    idPS=newSize
  ENDFUNCTION Test_MoveAllocFunc !}[/fortran]
What am I missing?
I am using windows 7x64, VS2010, Composer 2013 latest update.
Thanks for any help.
Dirk
Simon_Geard
They're not allocatable they're pointer. If you delete lines 12 and 14, remove the initialization in line 10 and replace POINTER with ALLOCATABLE do you still get an error?
A__Valle
Thanks for the fast response. This is very clear as well from the message when I read it again.
My fault
Dirk
