Error installing on Ubuntu
Aditya_K_
I am unable to install Intel Fortran Compiler XE for Intel(R) 64 component on Ubuntu 14.04. It says 'Unsupportted OS' at first. However, if I ignore and continue, select Intel 64 architecture, at Installation stage I get the error:
Installing Intel Fortran Compiler XE for Intel(R) 64 component...
ERROR: Unable to extract data from RPM package. Please check that temporary
directory is not full.
Please help.
Aditya
Which version of the compiler are you trying to install? Have you read https://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu ?
Ron_Green
The installer will use /tmp to extract files.  How full is your disk, and do you have permission to write to /tmp?
touch /tmp/foo
should succeed.
df -k  will show how much disk space you have.  Look for root, or "/" as tmp is directory under your root partition.
if for some reason your root partition is full or you don't have permissions on /tmp let me know..  There is a way to specify another directory for extraction and use during installation.
ron
Aditya_K_
There seems to be enough space: df -h shows this:
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda7        28G   11G   16G  40% /
none            4.0K     0  4.0K   0% /sys/fs/cgroup
udev            1.8G  4.0K  1.8G   1% /dev
tmpfs           365M  1.3M  364M   1% /run
none            5.0M     0  5.0M   0% /run/lock
none            1.8G  1.3M  1.8G   1% /run/shm
none            100M   48K  100M   1% /run/user
/dev/sda9       267G   16G  238G   7% /home
/tmp is not separately partitioned. It is under / directory, with 16GB free space
Just as an aside, is there any role for the 'tmpfs' mounted on /run here?
Aditya
Aditya_K_
I am trying to install
l_fcompxe_2013_sp1.3.174
Aditya
Aditya_K_
Any leads on this issue? I am waiting to hear from you :)
- Aditya
Ron_Green
Is it possible that your RPM database is locked?  http://www.oldrpm.org/hintskinks/repairdb/
Usually the simple
rm -f /var/lib/rpm/__db* will remove the files which hold lock state information (these files start with that distinctive "__"). As these lock state holding files are automatically re-created if missing, this is a safe approach.
have you rebooted lately?
And is the rpm package installed on your system?
ron
Ron_Green
You did say / is not full.  But did you check that you have write permissions on /tmp?
Are you installing as root user or a normal user?
ron
