29342 Discussions
Error message improvement suggestion (structure length)
jimdempseyatthecove
When the following error message is generated:
... warning #6380: The structure length is not a multiple of its largest element; could create misalignments for arrays of this type. [...]
I think it would be helpful to provide the missing information, such as:
... warning #6380: The structure length (nnn) is not a multiple of its largest element (mmm); could create misalignments for arrays of this type. [...]
Jim Dempse
jimdempseyatthecove
Similar thing with
...warning #6379: The structure contains one or more misaligned fields.
If you could list the first misaligned item, it would help immensely in locating the error (problem)
Jim Dempsey
