29263 Discussions
Error occured when unpacking the file "W_FCP_P_9.1.024.exe".
evan804
After I had finished downloading the executable file "W_FCP_P_9.1.024.exe", I ran it and operated following the installing guide. At first, the installation program read the package, and then it checked the package's integrity. At this moment, error occured and a message was given "The contents of this file cannot be unpacked. The executable you are attempting to run has been corrupted. Please obtain another copy of the file, verify its integrity, and try again.".
I downloaded the file at the second time and trid on another two computers using the same operating system, and finally received the same error!
I need your help, thank you. Is there some problems in that file "W_FCP_P_9.1.024.exe"?
Our OS is "Windows XP Professional SP2".
Steven_L_Intel1
There is not a problem in the package, but there may be a problem with the way you downloaded. If you are using MSIE and do a right-click, save-as on the download link, it is likely that the download will be corrupted. This is an interaction between MSIE and the Intel server and the problem is under investigation.
Instead, left-click on the link and allow the browser to prompt you to save the file. That will avoid the problem.
This is mentioned on the download site and in the description of the download.
evan804
I downloaded that file using "Net Transport v1.94" with multi-thead transport method which is the possible problem.
Thank you, Steve. I will try another time with single thread.
