29377 Discussions
Error running setvars.sh on Windows 10
kiriaki
Hello.
I've recently installed OneAPI Base and HPC toolkits v.2023 in a Windows desktop for a customer. The installation went smoothly, but when I run the setvars.sh script to setup the Fortran environment (both manually and from Visual Studio menu) I get the error message
\SSH was unexpected at this time.
System specs:
Processor: Xeon E5-2609v3
GPU: Nvidia Quadro M2000
A colleague of mine suggested that the problem lies with the Graphics card. Could that be true? If I understand well, the GPU is used to accelerate the code, but the compiler will use the CPU if a compatible GPU is not found.
Any ideas what may be causing this?
Steve_Lionel
The graphics card is irrelevant, and I assume you meant to say setvars.bat as there is no setvars.sh on a Windows system.
The Intel setvars.bat doesn't contain "SSH".
Open a command prompt window and type:
call "%ONEAPI_ROOT%setvars.bat"
Paste the entire command session into a reply here so we can see what is going on.
