I'm trying to set the variables after installing the packages intel-basekit and intel-hpckit through the apt package manager. No issues occurred during installation.
When I try to source the variables using the setvars.sh script, I get the following error.
:: initializing oneAPI environment ...
bash: BASH_VERSION = 5.0.17(1)-release
args: Using "$@" for setvars.sh arguments:
:: ERROR: No env scripts found: No "env/vars.sh" scripts to process.
This can be caused by a bad or incomplete "--config" file.
Can also be caused by an incomplete or missing oneAPI installation.
I've read through the documentation in length and couldn't find answers.
Following this answer for zsh shells here, I tried running
bash -c 'source setvars.sh'
bash -c 'source /opt/intel/oneapi/compiler/latest/env/vars.sh'
There were no immediate errors, and the environment appeared to be initialized. The $PATH and $LD_LIBRARY_PATH variables contain /opt/intel/oneapi... paths in them. However, when I run ifort to compile a basic program, it throws the error:
ld: cannot find -lgcc
ld: cannot find -lgcc_s
My system details are the following:
$ lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
$ uname -r
5.15.0-46-generic
$ uname -m
x86_64
strange - I tried to set that alias and no issue. I also changed link /bin/sh to /bin/dash. no issues.
$ alias
alias ls='ls --color=auto'
rwgreen@orcsle156:~$ !source
source /cts/tools/oneapi/2022.2.0-up1/setvars.sh
-bash: BASH_VERSION = 5.0.17(1)-release
:: advisor -- latest
:: ccl -- latest
:: clck -- latest
:: compiler -- latest
:: dal -- latest
:: debugger -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: dpcpp-ct -- latest
:: dpl -- latest
:: inspector -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: itac -- latest
:: mkl -- latest
:: mpi -- latest
:: tbb -- latest
:: vtune -- latest
:: oneAPI environment initialized ::
setvars.sh finds all the vars.sh scripts under /opt/intel/oneapi/*/latest/env
something in creating that list is wrong. so time for the big debug hammer.
sudo bash
# to get a root sudo shell
Edit /opt/intel/oneapi/setvars.sh
first line, change
/bin/sh
to
/bin/sh -x
exit the sudo shell, go back to user.
then source setvars.sh and capture the output. like this
source /opt/intel/oneapi/setvars.sh |& tee source.log
let's see what is going wrong
- « Previous
- 1
- 2
- Next »
I tried logging everything using set -x like you suggested. The logs showed that every time a cd command was invoked, something funny was going on. I had customised cd to automatically display the files in the directory every time I did a cd, using the following function in .bash_aliases.
32 # for auto ls after cd
33 function cd {
34 builtin cd "$@" && ls
35 }
This was the cause of the problem. I've never had this issue with any scripts before, so it never crossed my mind.
I'm sorry I couldn't find this earlier as it was not set as an alias to cd or in .bashrc.
Once, I disabled it, the setvars.sh worked perfectly.
Thanks @VarshaS_Intel and @James_T_Intel for the help too!
Ah, yes! 'cd', should have thought of that one! Good catch.
The setvars.sh uses the unqualified names for 'ls' and 'cd' because some distros put those in /bin and others in /usr/bin. So we can't fully path them.
btw - that is a really cool customization for 'cd'. Wish I could use it myself. hmm, maybe if we use "mycd" or some other shorthand name that doesn't alias another command.
I'll keep this issue in mind if we run into something similar in the future. Thanks for bringing this to us!
- « Previous
- 1
- 2
- Next »
