29642 Discussions
Error using extended type constructor
sfranzen
Consider the following module (subprogram part left out) and program: [fortran]module testmodule implicit none type, public, abstract :: expr contains procedure, non_overridable :: eval procedure, non_overridable :: diff end type type, public, extends(expr) :: polynomial real, dimension(:), allocatable :: c end type polynomial type, public, extends(polynomial) :: posynomial real, dimension(:), allocatable :: p end type posynomial contains [...] end module testmodule[/fortran] [fortran]program main implicit none
use testmodule
type(polynomial) :: poly type(posynomial) :: posy poly = polynomial([1., 2., 3.]) ! OK posy = posynomial([1., 2., 3.], [0., 1., 2.5]) ! throws compiler error #8212 end program main[/fortran] Compiling the above code with ifort 12.1.3.293 (build 20120212) gives me the error:
[bash]error #8212: Omitted field is not initialized. Field initialization missing:
posy = posynomial([1., 2., 3.], [0., 1., 2.5]) ^[/bash] even though the additional field [0., 1., 2.5] is evidently present. The above code compiles and runs without issues when I compile it with gfortran. A compiler bug?
Edit: Interestingly, it does compile properly when I invoke the constructor with posy = posynomial([1., 2., 3.], p = [0., 1., 2.5]) or posy = posynomial(c = [1., 2., 3.], p = [0., 1., 2.5]).
Yes, it's a compiler bug. It also goes away if type expr has components. I will report this to the developers - thanks for bringing it to our attention. Issue ID is DPD200180239.
This has been fixed for a release later this year.
