Error when use variables in Fortran module
cheng__bin
I am encountering a very very strange error when I use variables in Fortran module with intel/18.0.2.
It's a quite simple code. Each column of 'F' is calculated by each column of 'X'. They are both variables in module global. Below is the code.
In global.f90: declaration of the module.
module global
implicit none
!  Parameters
real(8),parameter :: GravConst = 6.674184D-11
real(8),parameter :: PI = 3.141592653589793D0
integer :: N
real(8) :: X(3,2)
real(8) :: F(3,2)
real(8) :: omega
real(8) :: density
end module
In main.f90: calculation of 'F'.
program main
use global
implicit none
integer I,J,K
N = 2
F = 0.0D0
X = 0.0D0
omega = 1.0
density = 0.0
!  read positions
open (1,FILE="pos.txt")
do I = 1,N
    read(1,*) (X(K,I),K=1,3)
end do
write(*,*) 'X:',(X(J,2),J=1,3)
write(*,*) 'F:',(F(J,2),J=1,3)
write(*,*) 'F(1,2):',omega*omega*X(1,2)- 4.0D0/3.0D0*PI*GravConst*density*X(1,2)
write(*,*) 'F(2,2):',omega*omega*X(2,2)- 4.0D0/3.0D0*PI*GravConst*density*X(2,2)
do I = 1,N
    !yorp force
    do K = 1,2
        F(K,I) = F(K,I) + omega*omega*X(K,I)
    end do
    !gravity
    do K = 1,3
        F(K,I) = F(K,I) - 4.0D0/3.0D0*PI*GravConst*density*X(K,I)
    end do
end do
write(*,*) (F(J,2),J=1,3)
end
F(1,2) and F(2,2) calculated directly are printed before the loop. Note that omega=1, and density=0, so F(1,2) and F(2,2) should equal to X(1,2) and X(2,2), respectively. After the loop, the final values of F(:,2) are printed. Here is the result using intel/18.0.2. It's obvious that the result calculated by the loop is wrong.
X: -4.97716000000000       0.897938000000000       -11.4228000000000
F: 0.000000000000000E+000  0.000000000000000E+000  0.000000000000000E+000
F(1,2): -4.97716000000000
F(2,2): 0.897938000000000
-4.69400000000000       -4.97716000000000    0.000000000000000E+000
It seem like something strange happening in the loop... But if I change the order of the calculation in the loop, the result would be correct.
do I = 1,N
    !gravity
    do K = 1,3
    end do
    !yorp force
    do K = 1,2
    end do
end do
-4.97716000000000       0.897938000000000    0.000000000000000E+000
If I use local variables rather variables in module, or use intel/15.0.6, the result would also be correct.
Below are pos.txt and makefile I used.
2.64530000  -7.20517000     -4.69400000
-4.97716000     0.89793800  -11.42280000
# Start of the makefile
COMPILER=ifort -O2
DEMBody: global.o main.o
    $(COMPILER)  -o DEMBody global.o main.o
global.mod: global.o global.f90
    $(COMPILER)  -c global.f90
global.o: global.f90
main.o: global.mod main.f90
    $(COMPILER)  -c main.f90
clean:
    rm global.mod global.o main.o
# End of the makefile
Or, you could try this input. It would be more clear.
    X(1,1) = 1.0
    X(2,1) = 2.0
    X(3,1) = 3.0
    X(1,2) = 4.0
    X(2,2) = 5.0
    X(3,2) = 6.0
You would get a confusing result for 'F':
    F(:,1): 1.000        2.000       0.000E+000
    F(:,2): 3.000        4.000       0.000E+000
The correct result should be
    F(:,2): 4.000        5.000       0.000E+000
It seems that the element of X/F has been moved by one cell.
gib
New Contributor II
This is indeed strange.  My old compiler (11.075) gives the correct results.
mecej4
This appears to be an optimizer bug. Compiling with the /Od option leads to correct behavior.
Please report the bug to https://supporttickets.intel.com/servicecenter?lang=en-US .
cheng__bin
Yes, I tried '-fp-model strict' and got correct result. It seems that compilers after intel/17.0.7 has this bug.
