29649 Discussions
Error while linking FFTW in the Visual Environment
david_sallngc_com
Hi Everyone!
I have written a FORTAN 90 code that uses the FFTW libraries as provided from the FFTW website. I can successfully create an executable via the command line using the Intel Fortran compiler as,
> ifort foo.f90 libfftw3-3.lib
and it works great. I have tried compiling in the Visual environment and continually get LINK errors where the compiler does not recognize the calls to FFTW. I can not seem to find project properties to change in order for the compiler to find the FFTW libraries. I have modified the Project Properties "Linker" configuration "Additional Library Directories" to point to hwere the FFTW library is located. Also, under the "Custom Build Step", I have included in the "Additional Dependencies" the library name, "libfftw3-3.lib".
Could someone please help steer me in the right direction as to how I configure the Project Properties to properly link the FFTW libraries?
Thank you very much.
Sinerely,
David
The simplest method is to add the .lib as a "source file". The approach you took is close - the "Additional Dependencies" property you want is under Linker > General.
Paul_Curtis
Valued Contributor I
This is the way that works, and adding a library as a dependency does not.
But why should this be so? Is this an artifact of Visual Studio? Why doesn't adding dependencies work as well?
It does work - I do this a lot.
david_sallngc_com
Hi Steve!
Thanks for the help. Adding the FFTW library as a source file works! I never would have thought of adding a library file as a source.
Sincerely,
David
seabstian1134
Hi!
I have the same problem as david, but I can not find the specified property. Could you please elaborate the process for me. I am using MCVS 2008, maybe it differs.
thanks a lot,
Sebastian
Sorry - I meant Linker > Input.
seabstian1134
Thanks, but I think I did this already. I have included libfftw3-3.lib as an additonal dependency in linker->input. The library is read in, but I still get the linker issues. I must have gone wrong at one point, so I will start the process from the front.
Thanks for your fast reply!
If you open a "Fortran Build Environment" command prompt and do a:
dumpbin -symbols yourlib.lib > lib.txt
lib.txt will list all the symbols found in the library. Compare that to what the linker says it can't find.
