29382 Discussions
Error with associate to character parameter
MR
ifort does not compile the attached code, which I think is legal
program p
 implicit none
 character(len=*), parameter :: text = "message text"
 associate( msg => text )
 write(*,*) msg
 end associate
end program p
The error is
ifort test.f90 -o test
test.f90(6): error #6404: This name does not have a type, and must have an explicit type.   [MSG]
 write(*,*) msg
compilation aborted for test.f90 (code 1)
and happens for both versions:
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.0.098 Build 20160721
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.2.181 Build 20160204
Marco
Thanks for the nice test case - escalated as issue DPD200414550. I note that if IMPLICIT NONE is not used, then MSG is implicitly typed and is some uninitialized value. It works ok for integer parameters and character variables.
mecej4
Curiously, if IMPLICIT NONE is removed, the program runs and prints
         109
which is the ASCII code for the first character of the message string!
I had thought that the associate name should be inheriting its type and other properties from the selector, and not be governed by implicit typing rules at all.
Yes, I saw the same thing. Clearly in the CHARACTER, PARAMETER case the type isn't coming along for the ride.
