29649 Discussions
Executable directory misdirection
nvaneck
My project disk drive changed from E: to D:. Everything compiles to the correct places on the D: drive but when trying to start the execution (Debug or release) it can't find the newly created executables. It looks for E:\.... and of course that doesn't exist. It must be something simple, but I can find no reference to E: anywhere in options or project files. Where does it set this path? All I can find is references to relative paths.
Jugoslav_Dujic
Valued Contributor II
Quoting - nvaneck
My project disk drive changed from E: to D:. Everything compiles to the correct places on the D: drive but when trying to start the execution (Debug or release) it can't find the newly created executables. It looks for E:.... and of course that doesn't exist. It must be something simple, but I can find no reference to E: anywhere in options or project files. Where does it set this path? All I can find is references to relative paths.
Try deleting the (hidden) SolutionName.suo file from your solution directory. It contains debug target, breakpoint locations, bookmarks and similar stuff. It is known to go berzerk on occasion.
Steven_L_Intel1
Project >Properties > Debugging > Command. Look also at Linker > Output File.
nvaneck
Yes, well I did that before I posted and it says:
$(OUTDIR)/MicrOsiris.exe
Which doesn't help me. As I said in the post, the files DO go in the correct directory. It's just that the debugger can't find the executable, thinking it's on a non-existent drive instead of where the linker put it.
Steven_L_Intel1
What does it say under Debugging > Command Line? That's where Visual Studio will look for the program.
nvaneck
It says:
$(TargetPath)
but I can't find where it'svalue is set....
nvaneck
Quoting - nvaneck
It says:
$(TargetPath)
Re-creating the project is the only way I've found to get around this.
Steven_L_Intel1
$(TargetPath) is, as I understand it, taken from the Linker's output setting.
nvaneck
Yes, and I tried copying it fromthe linker to the debug target, but still didn't work. Apparently the original dirve letter just gets stuck somewhere invisibly--edit seachs everywhere I could think of failed to find it.
Steven_L_Intel1
Please attach the .vfproj file for yoiur project.
nvaneck
Ok; here it is.
Jugoslav_Dujic
Quoting - nvaneck
nvaneck
Quoting - Jugoslav Dujic
That's it! Thanks, Juroslav. Your suggesion was on the money. It does have the E: reference in it and deleting it fixed the problem
