When I Open a file that has a path with blank spaces, e.g C:\Program files\etc...) the file is not found because it is truncated to C:\Program
Is there a way to have fortran get the full path and name with blank spaces?
Reinaldo
Quoting - Reinaldo
When I Open a file that has a path with blank spaces, e.g C:Program filesetc...) the file is not found because it is truncated to C:Program
Reinaldo
Enquote the quotes (you have both ' and " for quotes)
'"C:Program Files"'
How is this filename getting to Fortran? Is it a command line argument? You'll see the same behavior for many applications. Enclosing the filename in quotes ("") will handle that.
If it's just in an OPEN, then embedded blanks in a file specification are fine.
Quoting - Steve Lionel (Intel)
Thanks Steve:
I use the GETARG subroutine to assign from the command line argument the file name to a character variable. The file name may have blank spaces. I then use the fullpathqq and splitpathqq functions to extract the path, which I assign to anothervariable. In both cases I get the names trucated when there is a blank space. What can I do in those cases?
Thanks so much,
Reinaldo
Quoting - Reinaldo Garcia
Thanks Steve:
Thanks so much,
Reinaldo
I would expect that you need to surround the argument in the command line with double quotes. As mentioned earlier, this behavious is common with other Windows programs.
David
