Hi!
I have unsuccessfully been trying to compile a mexfunction in Matlab using FFTW on a 64-bit OS. It works perfectly on my 32-bit Windows XP computer. I can build either a static or dynamic binary and it works great. For the 32-bit OS, I compile using,
> mex foo.f90 mkl_intel_c.lib mkl_intel_thread.lib mkl_core.lib libguide40.lib fftw3xf_ms.lib
where I generated the fftw3xf_ms.lib file using Microsoft Visual Studio 2005.
This generated foo.mex32 and it works perfectly. I then went to the 64-bit Windows XP computer and invoked the command,
> mex foo.f90 mkl_em64t mkl_intel_thread.lib mkl_core.lib libguide40.lib fftw3xf_ms.lib
where all of the libraries are located in the em64t\lib MKL directory. This time, however, I get the link error, 2019, where all of the FFTW library calls are unrecognized. I also modified the mex command with the exact path names to each file but this did not work either.
If I compile foo.f90 and comment out the FFTW calls within the code, the executable runs perfectly.
Is there soemthing I am missing going to the 64-bit OS?
Thank you very much for your help.
Sincerely,
David
Sincerely,
David
Please post a few of the linker error messages with the full and complete text. My guess is that either you're linking against 32-bit FFTW libraries or you have some interface declarations that explicitly specify the external name and improperly include a leading underscore decoration.
Quoting - Steve Lionel (Intel)
Hi Steve!
After reading your response, I went and looked more closely how I generated the MKL FFTW library, fftw3xf_ms.lib. I believe that I did indeed create it in 32-bit mode and have corrected that but I still have errors. This is what I have done,
1) Opened a command window from Visual Studio 2005 and envoked the bat file, vcvarsamd64.bat which set the environmental variables for X64 build.
2) cd c:program filesIntelMKL10.0.5.025interfacesfftw3xf
3) Ran the makefile,
nmake libem64t compiler=ms
This last step generated the file, fftw3xf_ms.lib and put it in the directory, c:program filesintelmkl10.0.5.025em64tlib
I then tried to create my mexfunction by invoking the command in the Matlab command window,
> mex foo.f90 'c:program filesintelmkl10.0.5.025em64tlibmkl_em64t.lb' 'c...libmkl_intel_thread.lib' 'c:...libmkl_core.lib' 'c:...liblibguide40.lib' 'c:...libfftw3xf_ms.lib'
Now Im get a lot of link errors such as,
LIBCMT.lib(tidtable.obj) : error LNK2005: _encode_pointer already defined in MSVRCT.lib(MSVCR80.dll)
LIBCMT.lib(name1.obj) : error LNK2005: name2 already defined in MSVCRT.lib (name 3)
where name1 = crtheap, fflush, memcpy, ...), name2 = _decode_pointer, _unlock, etc... name3 = MSVCR80.dll, cinitexe.obj, etc...)
LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs, use /NODEFAULTLIB:library
LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs, use /NODEFAULTLIB:library
libifcoremd.lib(libifcoremain.obj) : error LNK2019: unresolved external symbol MAIN__ referenced in function main
Am I any closer?!
Sincerely,
David
First, you should start your command prompt with Start > Intel Software Development Tools > Intel Fortran Compiler 11.x.xxx > Build environment for appliations running on Intel 64. This gives you access to both Fortran and MSVC.
When you build the libraries, you have to choose which C libraries you're going to use. I recommend explicitly setting this rather than relying on defaults. /MT is a good choice - that's the ifort default. This is why you are getting the conflict errors.
Hi Steve!
Sincerely,
David
