Executable problem Windows 7
adam1fac
I am an engineer and only write Fortran programs as and when required. In the past I have used Linux to create my code but in my present job I am using Windows 7. I only need to create a cmd line program to perform some calculations but I have a really basic problem that everytime I create an executable and run it, the cmd prompt instantly closes. This occurs even with a Hello World program!
I can see it completes the statetment in the code, it just closes the cmd prompt before I can see the output. I have have the same problem on either Windows 7 32 or 64bit. Does anybody know how I can resolve this?
Adam
Arjen_Markus
This is a consequence of using a program that is running from a graphical user-interface.
The console window exists only for the program's sake and disappears right after the
program finishes.
Open a DOS-box (via Start/Run ..., type "cmd" as the command). That gives you a command
window, like xterm in Linux, that exists independent of any program you run.
Arjen
adam1fac
Ok thanks Arjen, yeah that works. But it is really annoying to have type in the directory each time rather than clicking on an icon. I am sure that on occasions in the past when I have used xp or vista the program launched form the executable itself.
Arjen_Markus
Well, there used to be an option/feature that the DOS box would remain open. You had to do that via
the so-called PIF editor. What I normally do, is start the DOS box from my file manager and then
I am in the right directory (that is not possible via "Windows Explorer", AFAIK, but it is via "Total Commander", my personal favourite for working with files on Windows).
Arjen
psantos
Hello adam1fac,
perhaps you can try the following program:
[fortran]Program Hello
   USE IFPORT
   USE IFCORE
   implicit none
   LOGICAL(4)       pressed / .FALSE. /
   write(*,'(A)') 'Hello World!'
   write(*,'(A)') 'Press any key to close ...'
   DO WHILE (.NOT. pressed)
        pressed = PEEKCHARQQ ( )
        CALL SLEEPQQ (200)
   END DO
End Program Hello[/fortran]
This modified hello program will only exit when you press a keyboard key. Hope this helps.
Pedro
anthonyrichards
New Contributor III
..or just program in a 'PAUSE' and it will ask you to press any key to continue...and close the console window.
Let me suggest an easy alternative. If you are building from the command line, add /libs:qwin to the ifort command. If you are building in Visual Studio, select "QuickWin" as the project type rather than console. Your program will run when you double-click the EXE and the console output will appear in a window which will stay around until you request that it be closed.
peterklaver
Quoting adam1fac
In Windows 7, you can over a folder in the Explorer window, and that brings up a menu that includes "Open command window here". That will save you some typing, although Steve's suggestion is (not surprisingly) the most elegant.
