Good day,
I have coded a simple test
[fortran]MODULE foo_1_class
IMPLICIT NONE
PRIVATE
TYPE, public :: foo_1
PRIVATE
integer :: xx = 1
CONTAINS
PRIVATE
procedure, public :: getX
END TYPE foo_1
CONTAINS
ELEMENTAL integer function getX(this) RESULT(res)
implicit none
class(foo_1), intent(IN) :: this
res = this%xx
return
end function getX
END MODULE foo_1_class
MODULE foo_2_class
USE foo_1_class
IMPLICIT NONE
PRIVATE
TYPE, public, extends(foo_1) :: foo_2
PRIVATE
integer :: yy = 3
CONTAINS
PRIVATE
procedure, public :: calc
END TYPE foo_2
CONTAINS
ELEMENTAL integer function calc(this) RESULT(res)
implicit none
class(foo_2), intent(IN) :: this
res = this%getX() + this%yy
!res = this%xx + this%yy ! Why could I not type this way?
!!! error #6292: The parent type of this field is use associated with the PRIVATE fields attribute [XX]
return
end function calc
END MODULE foo_2_class
PROGRAM main
USE foo_2_class
IMPLICIT NONE
type(foo_2) :: foo
write( *, * ) 'res is ', foo%calc()
END PROGRAM main[/fortran] I don`t understand. The all instance variables of foo_1 areinherited by foo_2. I suposed that an access to these ones should be possible through the foo_2_class module (with help of the class key-word). But I got the error message.
I compiled by ifortVersion 12.0.3.174 Build 20110309 withFC := ifort -g -traceback -check all -openmp -std03
Oleg.
As the compiler notes, you have made component xx PRIVATE, and therefore it is not accessible outside the module where it is declared. The ability to restrict access to individual components is important in structured programming, hence the use of get functions. You can access yy because it is defined in the same module as the reference. Type extension does not cause accessibility to be ignored.
I thought so and I decided to check it up.
Oleg
