29631 Discussions
Executing without building other projects within solution
forall
Is there any way to disable this feature?
In the past I would hit "Execute" and CVF would compile/build/execute whatever is necessary in the project - precisely what I needed.
The new interface doesnt seem to allow that - it will try to compile all other projects within the solution. At best this is time wasteful, at worst it requires other projects to be buildable.
You can right click on the project and select Debug.
nijhuis
The Tools/Options dialog box has the solution for this feature. Select the Environment folder and the item Projects and Solutions.
Set the checkbox for the item: "Only build startup projects and dependencies on Run" . The behaviour for build will be the same as we are used to have in CVF.
Guus
