Exporting a module from a .dll
David_Mccabe
Quick question here.
I have a module contained in a .dll and I would like to export all of the procedures in this module.
Infact I would like to export the module so that I can "use" it outside the .dll in another Intel fortran project.
I have tried the following:
[bash]module myModule
!dec$ attributes dllexport :: myModule
...module stuff...
end myModule[/bash]
to which I get the following warning:
Warning 1 warning #7645: Use of DEC$ ATTRIBUTES directive with module names is accepted, but has no effect.
Please could somebody tell me the correct way of doing this.
David_Mccabe
ok,I guess I must export every module procedure individually or alternatively use a static library
That is correct - you cannot do a mass export of everything in a module, you must name the individual symbols you want exported. Also, the ATTRIBUTES DLLEXPORT directive must be in the scope where the symbol is declared. For procedures, this would be inside the procedure.
