Have ICE with small/simple program
lklawrie
I have a Internal Compiler Error with a small simple program. I have worked around it but though you might want it for the developers. Include it here or submit it as a ticket?
Here works - up to you.
lklawrie
Here you go. Was a bit of a surprise to have an ICE.
How very amusing. It has to do with the structure constructor you use to initialize alltimeweather - it is missing a value corresponding to the array component dayrain at the end. This should be ok, but is giving the compiler heartburn. Just stick in a 0.0D0 as the corresponding value and it will be happy. I will let the developers know.
lklawrie
Figured that out. Actually changed that small array to be up with the other part of the structure -- it was easier than trying to do anything with the alltimeweather init.
Issue ID is DPD200177511.
Turns out that the real issue is that when you declared the dayrain component you supplied a scalar as the initial value. If you made that an array, it would be happy too.
lklawrie
Interesting. It's happy with it in the structure that way.
See attached.
It's not the type declaration that triggers the problem, it's a structure constructor that omits a value for an array component initialized with a scalar. Your new code doesn't do that.
lklawrie
no problemo.
thanks for the help.
The problem reported has been fixed for a future product release.
