29422 Discussions
FILENAME is "undefined address" with USEROPEN
Burton_R_
I am trying to implement writing to a named pipe with a USEROPEN function (written in Fortran).  when the useropen function is called, the FILENAME is "Undefined Address".  If I simply hard-code the pipe name everything works as expected, but obviously that not going to work for production.  Here's my code.  I am a Fortran newb, so please don't hesitate to critique any part of this.
    module fortranpipe
        implicit none
    contains
        subroutine writetopipe()
            !dec$ attributes dllexport :: writetopipe
            !dec$ attributes alias : "writetopipe" :: writetopipe
            implicit none
            integer*4 :: i
            OPEN(UNIT=10,FILE='\\.\pipe\testpipe',STATUS='OLD', ACTION='WRITE', useropen = uopen)
            print*, "open called"
            do i = 1, 10
                write (10, *) 'Hello World!'
            end do
            close(10)
        end subroutine
        INTEGER FUNCTION UOPEN(FILENAME, DESIRED_ACCESS, SHARE_MODE, A_NULL, CREATE_DISP, FLAGS_ATTR, B_NULL, UNIT, FLEN)
            !DEC$ ATTRIBUTES C, ALIAS:'_UOPEN' :: UOPEN
            !DEC$ ATTRIBUTES REFERENCE :: FILENAME
            !DEC$ ATTRIBUTES REFERENCE :: DESIRED_ACCESS
            !DEC$ ATTRIBUTES REFERENCE :: SHARE_MODE
            !DEC$ ATTRIBUTES REFERENCE :: CREATE_DISP
            !DEC$ ATTRIBUTES REFERENCE :: FLAGS_ATTR
            !DEC$ ATTRIBUTES REFERENCE :: UNIT
            USE IFWIN
            implicit none
            integer*4 :: DESIRED_ACCESS, SHARE_MODE, CREATE_DISP, FLAGS_ATTR, UNIT, A_NULL, B_NULL, FLEN, hFile
            CHARACTER*(FLEN) FILENAME
            character*(FLEN+1) :: pipename
            TYPE(T_SECURITY_ATTRIBUTES), POINTER :: NULL_SEC_ATTR
            logical :: waitstatus
            !FLAGS_ATTR = FLAGS_ATTR + FILE_FLAG_WRITE_THROUGH
            DESIRED_ACCESS = GENERIC_WRITE
            SHARE_MODE = 0
            CREATE_DISP = OPEN_EXISTING
            FLAGS_ATTR = FILE_ATTRIBUTE_NORMAL
            pipename = '\\.\pipe\testpipe' // char(0)
            waitstatus = WaitNamedPipe(pipename, 1000)
            UOPEN = CreateFile( pipename, DESIRED_ACCESS, SHARE_MODE, NULL_SEC_ATTR, CREATE_DISP, 0, 0 )
            RETURN
        END function
    end module
IanH
Separate to your USEROPEN question - consider (if you wanted to customise the CreateFile or pipe connection in some way the following might not be applicable) just using a normal Fortran OPEN statement to open the pipe and handling the specific "pipe not available" error code (perhaps in a loop with some sort of delay between attempts.  This is simpler and also avoids the race condition that exists in your current approach - there is a finite time between WaitNamedPipe and CreateFile where another process could steal the pipe.
I suspect what is happening is that you are relying on the debugger to find out what filename is, and the debugger is telling fibs - the actual filename is ok (and it already includes the null terminator).  But do note that Fortran pointers and C pointers are different - you never define NULL_SEC_ATTR so the reference to it in the CreateFile call is an error.  Instead simply pass NULL for that parameter.
Burton_R_
you're absolutely correct on both points.  I had originally tried opening the pipe without the USEROPEN function, but failed because some of the parameters were wrong.  now that I have all that worked out with the USEROPEN working, opening the pipe without USEROPEN is also working.  Also, now that I have the remaining options correct, i was stopping in the debugger to inspect FILENAME, but never tried just passing FILENAME to CreateFile.    THANKS!
Burton_R_
Here's the code i ended up with:
    module fortranpipe
        implicit none
    contains
            use kernel32
            implicit none
            integer*4 :: i, ios, lasterror
            character*17 :: pipename
            do
                open(unit=10, file=pipename, status='OLD', action='WRITE', iostat=ios)
                if (ios == 0) exit
                waitstatus = WaitNamedPipe(pipename // char(0), 1000)
                lasterror = GetLastError()
                if (waitstatus == .false. .OR. lasterror /= 0) exit
            end do
            if (ios /= 0) then
                ! do something with the err
            endif
            do i = 1, 10
            end do
            close(10)
        end subroutine
    end module
