29285 Discussions
FINAL binding to an ELEMENTAL procedure does not work: causes "Program Exception - Access Violation"
FortranFan
Consider the simple program shown below:
MODULE m
   IMPLICIT NONE
   !.. Private by default
   PRIVATE
   TYPE, PUBLIC :: t
      !.. private by default
      PRIVATE
      !.. Private fields
      CHARACTER(LEN=:), ALLOCATABLE :: m_string
   CONTAINS
      PRIVATE
      FINAL :: Clean
      PROCEDURE, PASS(This), PUBLIC :: Set => Set_String
      PROCEDURE, PASS(This), PUBLIC :: Get => Get_String
   END TYPE t
CONTAINS
   PURE ELEMENTAL SUBROUTINE Set_String(This, NewString)
      !.. Argument list
      CLASS(t), INTENT(INOUT)      :: This
      CHARACTER(LEN=*), INTENT(IN) :: NewString
      This%m_string = NewString
      RETURN
   END SUBROUTINE Set_String
   PURE ELEMENTAL FUNCTION Get_String(This) RESULT(RetVal)
      !.. Argument list
      CLASS(t), INTENT(IN) :: This
      !.. Function result
      CHARACTER(LEN=:), ALLOCATABLE :: RetVal
      RetVal = This%m_string
      RETURN
   END FUNCTION Get_String
   PURE ELEMENTAL SUBROUTINE Clean(This)
      !.. Argument list
      TYPE(t), INTENT(INOUT)      :: This
      !.. Local variables
      INTEGER :: Istat
      IF (ALLOCATED(This%m_string)) THEN
         DEALLOCATE(This%m_string, STAT=Istat)
      END IF
      RETURN
   END SUBROUTINE Clean
END MODULE m
PROGRAM p
   USE m, ONLY : t
   IMPLICIT NONE
   !.. Local variables
   TYPE(t), ALLOCATABLE :: foo(:)
   INTEGER :: Istat
   INTEGER, PARAMETER :: MaxElem = 5
   INTEGER :: I
   CHARACTER(LEN=2048) :: ErrDealloc
   PRINT *, " Test Elemental finalizer "
   ALLOCATE(foo(MaxElem), STAT=Istat)
   IF (Istat /= 0) THEN
      PRINT *, " Error allocating foo."
      STOP
   END IF
   DO I = 1, MaxElem
      CALL foo(I)%Set(" string " // ACHAR(34+I))
      PRINT *, " foo element ",I, " is ",foo(I)%Get()
   END DO
   DEALLOCATE(foo, STAT=Istat, ERRMSG=ErrDealloc)
      PRINT *, " Error deallocating foo: STAT = ",Istat,", ERRMSG = ", ErrDealloc(1:LEN_TRIM(ErrDealloc))
      STOP
   END IF
   PRINT *, " End Program "
   STOP
END PROGRAM p
Upon compilation and execution with Intel Fortran, either compiler version 14 or 2015 Beta, the program fails as follows:
  foo element  1  is  string #
  foo element  2  is  string $
  foo element  3  is  string %
  foo element  4  is  string &
  foo element  5  is  string '
forrtl: severe (157): Program Exception - access violation
Image              PC        Routine            Line        Source
TestFor32.exe      00DA1494  _M_mp_CLEAN@4              66  TestMod.f90
TestFor32.exe      00DB13DA  Unknown               Unknown  Unknown
TestFor32.exe      00DA2467  _MAIN__                    28  TestFor.f90
TestFor32.exe      00E148A2  Unknown               Unknown  Unknown
TestFor32.exe      00E157BA  Unknown               Unknown  Unknown
TestFor32.exe      00E1590D  Unknown               Unknown  Unknown
kernel32.dll       7576338A  Unknown               Unknown  Unknown
ntdll.dll          76F5BF32  Unknown               Unknown  Unknown
ntdll.dll          76F5BF05  Unknown               Unknown  Unknown
My understanding is the above is consistent with current Fortran standard and the access violation is due to some bug in the compiler.  Can someone from Intel please investigate and provide feedback?
FortranFan
FWIW, the above program works with gfortran 4.9 - the code compiles without any errors and it runs with no errors or memory leaks.
FortranFan
A correction and a clarification:
  • I said, "Upon compilation and execution with Intel Fortran, either compiler version 14 or 2015 Beta, the program fails" - it is actually compiler 13 (version Compiler XE 13.1.1.171 to be exact) and 2015 Beta that I used for my testing.  I don't know the response with compiler version 14 - my apologies for any confusion.
  • As Yolanda Chen at Intel pointed out, the problem occurs with IA-32 (32-bit) build; Intel 64 (i.e., 64-bit) version runs fine.
Did you already report this through Intel Premier Support and got a response from Yolanda?
FortranFan
Steve,
My hunch is the problem with the simple code in this topic is connected with the more complex code in Premier Support incident 6000058970 I'd submitted over the weekend, so I've added a comment to that Premier incident about this new forum topic in case your engineering/development team feels the same and wishes to look at the two issues together.
Yolanda had pointed out earlier on the Premier incident about the differences between IA-32 and Intel 64 builds, so I retried the program in this topic for the two builds and found Intel 64 version ran ok.
It could just be a coincidence. Please add this information to the Premier Support issue so that Yolanda can track it properly.
You sent me a PM but I can't read any PMs right now. Since you already started a Premier Support issue on this topic, please continue it there to avoid duplication of effort.
FortranFan
Steve,
Thanks, I fully appreciate your comment about duplication of effort and I'll always remain fully cognizant of that.
Re: the Premier Support issue, sorry I wasn't fully clear in my comment in Quote #5 above.  The incident #6000058970 does indeed refer to a separate issue I'd mentioned in this forum topic about object-oriented list example from the book by Metcalf et al. - https://software.intel.com/en-us/forums/topic/518263 - see Quote #9 in there where I talk my own implementation of a list class similar to the MFE example and which runs into "access violation" error just like the MFE example.
My thoughts now are:
  1. the "access violation" error in my "list" class is different from that encountered while running the example code from MFE book,
  2. the "access violation" error in my "list" class is related to the error in the simple example in this topic with a FINAL binding to an ELEMENTAL procedure.
I could well be wrong, so I'll leave it all in Intel's good hands.
But to make a long story short, I think it is worth keeping my Premier Support issue #6000058970 and the one in this topic as two separate incidents with an alert to your development staff of a possible connection between the two.  If development comes and says they are indeed one and the same, then one of them can be closed out.
Lorri_M_Intel
Is this the program that has /iface:cvf set in the project property?
           --Lorri
FortranFan
Yes, is that a problem?  It doesn't need to have this setting - it is an unintended carry-over in my Visual Studio "template" for Fortran projects that was created from one that needed this setting for interfacing to another library that was built with CVF-style options.
Yes, it is a problem. We discussed this in our team meeting today. Turn /iface:cvf off if you don't need it. If you do need it, add !DEC$ ATTRIBUTES DEFAULT to any FINAL routines.
Yuan_C_Intel
Yes, I verified this runs successfully without /iface:cvf.
The same to the project in IPS incident #6000058970.
FortranFan
Thanks Yolanda and Steve.
Not that it might affect me, but out of curiosity, what is the forward plan for Intel re: this issue - users should not use /iface:cvf if they wish to implement final bindings for IA-32 systems or is this a temporary workaround until Intel has a fix?
The forward plan is to give a compile-time error if /iface:cvf or stdcall or stdref is in effect and you declare a FINAL procedure. This is similar to what we do for USEROPEN. We discussed options of making it work but decided that as this affects IA-32 Windows only, and only those who migrated from CVF (which didn't have FINAL procedures) and most of whom don't need /iface:cvf, it wasn't worth pursuing.
If you need /iface:cvf for specific routines, we now have !DEC$ ATTRIBUTES CVF you can use for convenience on those routines only. I'd say that the majority of people who have /iface:cvf enabled for their projects don't need it and should disable it. This can also bite you if you use IFLOGM or IMSL callbacks, both of which require the compiler's default calling convention.
Lorri_M_Intel
If you need/want to use /iface:cvf  you can add an explicit "default" attribute to your FINAL subroutine declaration using
!DEC$ ATTRIBUTES DEFAULT :: myFinalSubroutineName
             --Lorri
FortranFan
Thanks Steve and Lorri.
Would you consider adding this information to Intel Fortran documentation e.g., "User and Reference Guide for the Intel® Fortran Compiler"?  It'll be nice if in the Help Viewer for Visual Studio, when one looks up information for iface and looks at "/iface:cvf", there is a link perhaps to a section to all the caveats associated with this option including the one about FINAL and ELEMENTAL procedures.
We already have this:
Caution
On systems using IA-32 architecture, there must be agreement between the calling program and the called procedure as to which calling mechanism (C or STDCALL) is used or unpredictable errors may occur. If you change the default mechanism to STDCALL, you must use the ATTRIBUTES DEFAULT directive to reset the calling conventions for routines specified with the USEROPEN keyword in an OPEN statement and for comparison routines passed to the QSORT library routine.
I will have FINAL procedures added to this paragraph. (Looks like it needs to also talk about IFLOGM callbacks too, as well as IMSL.)
FortranFan
So Steve/Lorri,
Is the message here that coders should view FINAL bindings as an "external procedure"?  And that /iface settings are relevant even for all Fortran projects using Intel compiler that the coder may normally view as not calling any "external procedures"?
After all, the settings for /iface are lumped under the "External Procedures" section under Fortran for project properties in Visual Studio.  So I only worry about that section when I know I'll be calling procedures from another library (e.g., some DLL procedure) or when I'm doing mixed-language programming, etc.
For all Fortran projects like the console application I setup to test the code in the original post above, there are no explicit link-time or run-time dependencies to any non-system library/DLL.  For such projects, I have not been paying attention to "External Procedures" section in Visual Studio  - I guess I've been mistaken?
The option applies to any procedures that are compiled or called. It has nothing to do with run-time libraries.
